跳转到主内容
ZD-N Plus Wireless Controller Rumble Motor Replacement
你所需要的
  1. ZD-N Plus Wireless Controller Rumble Motor Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the seven 12mm JIS #00 screws that hold the back panel in place.
  2. ZD-N Plus Wireless Controller Rumble Motor Replacement: 步骤 2 中的图像 1,2 ZD-N Plus Wireless Controller Rumble Motor Replacement: 步骤 2 中的图像 2,2
    • Lift up on the back panel of the ZD-N Plus to remove it from the rest of the controller.
  3. ZD-N Plus Wireless Controller Rumble Motor Replacement, Battery: 步骤 3 中的图像 1,1
    • Use an opening tool to pry the battery from its original position.
    • The battery is glued on, so this may take some effort.
  4. ZD-N Plus Wireless Controller Rumble Motor Replacement: 步骤 4 中的图像 1,2 ZD-N Plus Wireless Controller Rumble Motor Replacement: 步骤 4 中的图像 2,2
    • Use an opening tool to pry the connector away from the two metallic prongs.
    • The parts are built to stay together, so this may take some effort.
    • Be careful to not warp the prongs in the process.
  5. ZD-N Plus Wireless Controller Rumble Motor Replacement: 步骤 5 中的图像 1,2 ZD-N Plus Wireless Controller Rumble Motor Replacement: 步骤 5 中的图像 2,2
    • Remove the battery from the controller.
  6. ZD-N Plus Wireless Controller Rumble Motor Replacement, Rumble Motor: 步骤 6 中的图像 1,2 ZD-N Plus Wireless Controller Rumble Motor Replacement, Rumble Motor: 步骤 6 中的图像 2,2
    • Remove the electrical connector attaching each rumble motor to the controller.
    • Lift up on the circular section of the rumble to remove it from the controller.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 15
总计 421
