跳转到主内容
Yuneec Typhoon H Plus Motor Replacement
你所需要的
  1. Yuneec Typhoon H Plus Motor Replacement, Motor: 步骤 1 中的图像 1,2 Yuneec Typhoon H Plus Motor Replacement, Motor: 步骤 1 中的图像 2,2
    • Flip the drone over so the bottom is facing upwards.
    • Remove ten 9.5mm Hex 2 screws attached to the bottom shell.
  2. Yuneec Typhoon H Plus Motor Replacement: 步骤 2 中的图像 1,3 Yuneec Typhoon H Plus Motor Replacement: 步骤 2 中的图像 2,3 Yuneec Typhoon H Plus Motor Replacement: 步骤 2 中的图像 3,3
    • Carefully detach the top billit piece from the drone. There are internal clips that need to be detached from the top piece in order for the entire unit to come off.
    • Once the lid is off, detach the wire that holds the lid to the body. Press down on the clip and slide the wire out.
  3. Yuneec Typhoon H Plus Motor Replacement: 步骤 3 中的图像 1,3 Yuneec Typhoon H Plus Motor Replacement: 步骤 3 中的图像 2,3 Yuneec Typhoon H Plus Motor Replacement: 步骤 3 中的图像 3,3
    • Find the base of the arm you are replacing and remove the electrical tape.
    • Disconnect the red, black, and blue wires. Also disconnect the white clip that is associated with those same wires.
    • You may need a pair of pliers to get enough grip to disconnect the three wires.
  4. Yuneec Typhoon H Plus Motor Replacement: 步骤 4 中的图像 1,3 Yuneec Typhoon H Plus Motor Replacement: 步骤 4 中的图像 2,3 Yuneec Typhoon H Plus Motor Replacement: 步骤 4 中的图像 3,3
    • Find the pin that holds the arm by pulling down the bottom shell. Use a Hex bit 2 screwdriver to remove it
    • After removing the pin, pull the arm and wires out of the drone.
  5. Yuneec Typhoon H Plus Motor Replacement: 步骤 5 中的图像 1,2 Yuneec Typhoon H Plus Motor Replacement: 步骤 5 中的图像 2,2
    • Use the wrench tool from the Yuneec drone box to remove the bottom cap from the motor mount. Twist clockwise until it pops; then it will slide out easily.
  6. Yuneec Typhoon H Plus Motor Replacement: 步骤 6 中的图像 1,2 Yuneec Typhoon H Plus Motor Replacement: 步骤 6 中的图像 2,2
    • Disconnect the electrical board from the wire and thread the clip through the arm to the side with the motor to remove the entire motor/wire assembly.
    • After both sides of the wire are on the side with the motor, pull the wires through the length of the arm.
结论
2等其他人完成本指南。
Brice Black
于01/23/20注册
557 声望
创作了4篇指南
团队
Cal Poly, Team S2-G1, White Winter 2020 Cal Poly, Team S2-G1, White Winter 2020 的会员
CPSU-WHITE-W20S2G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 10
总计 1,042
