跳转到主内容
Yuneec Typhoon H Gimbal Bushing Reattachment
你所需要的
  1. Yuneec Typhoon H Gimbal Bushing Reattachment, Gimbal Bushing Connectors to Camera Mount: 步骤 1 中的图像 1,2 Yuneec Typhoon H Gimbal Bushing Reattachment, Gimbal Bushing Connectors to Camera Mount: 步骤 1 中的图像 2,2
    • In order to repair the camera and camera gimbal, remove the camera configuration from the body of the drone.
    • Pull up on the tab connected to the camera configuration and slide the entire apparatus off.
  2. Yuneec Typhoon H Gimbal Bushing Reattachment: 步骤 2 中的图像 1,3 Yuneec Typhoon H Gimbal Bushing Reattachment: 步骤 2 中的图像 2,3 Yuneec Typhoon H Gimbal Bushing Reattachment: 步骤 2 中的图像 3,3
    • Put the gimbal bushings (the rubber balls) back into the plastic alignment mounts.
    • The circle that is separated from the main body of the bushing should then be inserted into the hole.
    • When pushing these bushings back into place, it is smart to use a skinny tool or toothpick.
结论
To reassemble your device, simply slide the camera mount back onto the bottom of the drone.
2等其他人完成本指南。
Jake Breul
于04/16/18注册
127 声望
撰写一个指南
团队
Cal Poly, Team S22-G3, Maness Spring 2018 Cal Poly, Team S22-G3, Maness Spring 2018 的会员
CPSU-MANESS-S18S22G3
4 名成员
创作了5篇指南
3条评论
Camera not getting power after crash.
Don - 回复
Crashed drone and camera not getting power anymore. Nothing appears to be broken.
Don - 回复
Did steps. Bushings ok. Camera still won't communicate.
vickiesamus - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 19
总计 1,639
