跳转到主内容
Yuneec Breeze 4K Motherboard Replacement
你所需要的
  1. Yuneec Breeze 4K Motherboard Replacement, Motherboard M7: 步骤 1 中的图像 1,2 Yuneec Breeze 4K Motherboard Replacement, Motherboard M7: 步骤 1 中的图像 2,2
    • Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery.
    • Flip over the drone so that the propellers are facing down and the camera is facing up.
  2. Yuneec Breeze 4K Motherboard Replacement: 步骤 2 中的图像 1,3 Yuneec Breeze 4K Motherboard Replacement: 步骤 2 中的图像 2,3 Yuneec Breeze 4K Motherboard Replacement: 步骤 2 中的图像 3,3
    • Grip the cover that covers the rest of the wires, and give it a slight pull to remove it.
  3. Yuneec Breeze 4K Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the 4 rubber plugs that hold the drone and its internal parts together.
    • These plugs can be located in each corner of the drone, and are white.
  4. Yuneec Breeze 4K Motherboard Replacement: 步骤 4 中的图像 1,1
    • Unplug the four cables that are connected on the top face of the frame.
  5. Yuneec Breeze 4K Motherboard Replacement: 步骤 5 中的图像 1,2 Yuneec Breeze 4K Motherboard Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • The rest of the wires that are still connected can be unplugged.
    • Using a pair of tweezers they can be unplugged.
  6. Yuneec Breeze 4K Motherboard Replacement: 步骤 6 中的图像 1,3 Yuneec Breeze 4K Motherboard Replacement: 步骤 6 中的图像 2,3 Yuneec Breeze 4K Motherboard Replacement: 步骤 6 中的图像 3,3
    • Lift up or tilt entire frame and mother board and unplug all the wires.
  7. Yuneec Breeze 4K Motherboard Replacement: 步骤 7 中的图像 1,3 Yuneec Breeze 4K Motherboard Replacement: 步骤 7 中的图像 2,3 Yuneec Breeze 4K Motherboard Replacement: 步骤 7 中的图像 3,3
    • The battery connector has two wires connected to a plug in with two little screws.
    • Unscrew the two screws and pull it apart using a small tweezers.
  8. Yuneec Breeze 4K Motherboard Replacement: 步骤 8 中的图像 1,1
    • Flip over the frame and mother board and unscrew the mother board.
    • There are four screws on each corner of the mother board.
  9. Yuneec Breeze 4K Motherboard Replacement: 步骤 9 中的图像 1,2 Yuneec Breeze 4K Motherboard Replacement: 步骤 9 中的图像 2,2
    • After the screws are out, the motherboard can be pulled out softly with hands.
    • Remove the motherboard from the device.
结论
5等其他人完成本指南。
Ryanne Millis
于10/04/18注册
318 声望
撰写一个指南
团队
UW Stout, Team S6-G5, Ogden Fall 2018 UW Stout, Team S6-G5, Ogden Fall 2018 的会员
UWSTOUT-OGDEN-F18S6G5
4 名成员
创作了4篇指南
一条评论
Excellent step by step instructions.
paul_courville - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 16
总计 1,945
