跳转到主内容
Yujin Robot iCLEBO Arte Power Transformer Replacement
  1. Yujin Robot iCLEBO Arte Power Transformer Replacement, Power Transformer: 步骤 1 中的图像 1,1
    • Unplug transformer before performing operations on it!
    • Press on the two black plastic tabs to remove the rear cover for the charging base.
  2. Yujin Robot iCLEBO Arte Power Transformer Replacement: 步骤 2 中的图像 1,1
    • Remove the long cable from inside the base and gently pull the connector from the base.
  3. Yujin Robot iCLEBO Arte Power Transformer Replacement: 步骤 3 中的图像 1,1
    • Pull out and remove the old cable from inside the charging base.
    • Detach the thicker part of the cord from the black transformer box.
  4. Yujin Robot iCLEBO Arte Power Transformer Replacement: 步骤 4 中的图像 1,1
    • Replace the new thick cable with the old cable just removed. Make sure the cable can fit into the wall before discarding the other cable. If you are residing in the US, this is the connector you need to use.
结论
Trent Bingel
于02/28/17注册
437 声望
创作了4篇指南
团队
USF Tampa, Team S2-G3, Nance Spring 2017 USF Tampa, Team S2-G3, Nance Spring 2017 的会员
USFT-NANCE-S17S2G3
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 687
