跳转到主内容
Yujin Robot iCLEBO Arte Main Brush Replacement
你所需要的
  1. Yujin Robot iCLEBO Arte Main Brush Replacement, Dust Bin: 步骤 1 中的图像 1,1
    • Remove the dust bin by gently pressing the silver button on top of the vacuum until the bin releases.
  2. Yujin Robot iCLEBO Arte Main Brush Replacement: 步骤 2 中的图像 1,2 Yujin Robot iCLEBO Arte Main Brush Replacement: 步骤 2 中的图像 2,2
    • Grip the bottom of the dust bin. Push up on the tabs as indicated by the yellow arrows.
    • Empty contents of bin into waste receptacle and rinse with water as needed.
  3. Yujin Robot iCLEBO Arte Main Brush Replacement, Main Brush: 步骤 3 中的图像 1,3 Yujin Robot iCLEBO Arte Main Brush Replacement, Main Brush: 步骤 3 中的图像 2,3 Yujin Robot iCLEBO Arte Main Brush Replacement, Main Brush: 步骤 3 中的图像 3,3
    • Flip over the device to access the brush cover.
    • To remove the brush cover, push together the two snap releases on the right and left sides of the cover until it releases.
    • Do not push the release snaps too close together. Doing so may cause them to break and the brush could fall out when in use.
  4. Yujin Robot iCLEBO Arte Main Brush Replacement: 步骤 4 中的图像 1,2 Yujin Robot iCLEBO Arte Main Brush Replacement: 步骤 4 中的图像 2,2
    • Grip the left side of the brush with the square end-piece and pull up until the brush pops out.
  5. Yujin Robot iCLEBO Arte Main Brush Replacement: 步骤 5 中的图像 1,3 Yujin Robot iCLEBO Arte Main Brush Replacement: 步骤 5 中的图像 2,3 Yujin Robot iCLEBO Arte Main Brush Replacement: 步骤 5 中的图像 3,3
    • When preparing a new brush, it is very important to make sure that the new one is equipped with the proper end-pieces.
    • Take the round metal piece and slide it into the square rubber coating. Then, stick it on the end with the metal peg.
结论
Trent Treiber
于02/28/17注册
204 声望
创作了2篇指南
团队
USF Tampa, Team S2-G3, Nance Spring 2017 USF Tampa, Team S2-G3, Nance Spring 2017 的会员
USFT-NANCE-S17S2G3
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 891
