跳转到主内容
Yujin Robot iCLEBO Arte Filter Replacement
  1. Yujin Robot iCLEBO Arte Filter Replacement, Dust Bin: 步骤 1 中的图像 1,1
    • Remove the dust bin by gently pressing the silver button on top of the vacuum until the bin releases.
  2. Yujin Robot iCLEBO Arte Filter Replacement: 步骤 2 中的图像 1,2 Yujin Robot iCLEBO Arte Filter Replacement: 步骤 2 中的图像 2,2
    • Grip the bottom of the dust bin. Push up on the tabs as indicated by the yellow arrows.
    • Empty contents of bin into waste receptacle and rinse with water as needed.
  3. Yujin Robot iCLEBO Arte Filter Replacement, Filter: 步骤 3 中的图像 1,1
    • Push the yellow tab releasing the filter harness.
  4. Yujin Robot iCLEBO Arte Filter Replacement: 步骤 4 中的图像 1,1
    • Replace or clean filter under a stream of water. When reinserting filter, make sure the filter's cut corner is in the correct corner.
结论
To finish reassembling your device, follow these instructions in reverse order.
Nathan Clark
于02/28/17注册
101 声望
撰写一个指南
团队
USF Tampa, Team S2-G3, Nance Spring 2017 USF Tampa, Team S2-G3, Nance Spring 2017 的会员
USFT-NANCE-S17S2G3
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 9
总计 311
