简介
To complete this guide you'll need a Philips #0 screwdriver and a spudger.
你所需要的
Flip the tablet with the rear panel facing up.
Push the central button to lift the support.
Open the support entirely, using your hands.
Remove the sticker using the plastic spudger by lifting it up from one side, then you can remove it entirely by using your fingers.
Use the Philips #0 screwriver to remove the three screws.
Divide the two halfs by inserting the spudger in the gap between the front shell and the rear one. To help you out with this job you can also use some guitar picks.
Do the same procedure on all three visible sides, including the two round side parts.
To reassemble the device, folllow these instruction in reverse order.
另外一个人完成了本指南。
由衷感谢以下译者:
100%
Domenyck Paoly正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
