跳转到主内容
Yobo Gameware Controller Trigger Spring Replacement
你所需要的
  1. Yobo Gameware Controller Trigger Spring Replacement, Back Panel: 步骤 1 中的图像 1,2 Yobo Gameware Controller Trigger Spring Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Be sure the controller is disconnected from the console or any source of power.
    • Place the controller (button - side down) on a clean, solid work surface.
    • Use your screwdriver to remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Yobo Gameware Controller Trigger Spring Replacement, Removing Back Panel: 步骤 2 中的图像 1,2 Yobo Gameware Controller Trigger Spring Replacement, Removing Back Panel: 步骤 2 中的图像 2,2
    • Gently life the back panel up, separating it from the front panel.
    • Some components could fall off the front panel if the controller is knocked around during this step.
  3. Yobo Gameware Controller Trigger Spring Replacement, Removing Triggers: 步骤 3 中的图像 1,3 Yobo Gameware Controller Trigger Spring Replacement, Removing Triggers: 步骤 3 中的图像 2,3 Yobo Gameware Controller Trigger Spring Replacement, Removing Triggers: 步骤 3 中的图像 3,3
    • Depress the trigger assembly using your index finger while using your thumb to keep upward pressure on the grey square bracket and clear circular component on the underside of the trigger assembly.
    • Maintain a firm grip on the entire assembly, as the components could spring apart if you release pressure.
    • Rotate the assembly upwards and towards you to remove it from its housing in the controller.
    • The removal process is the same for both the left and right triggers.
  4. Yobo Gameware Controller Trigger Spring Replacement, Replacing Spring: 步骤 4 中的图像 1,2 Yobo Gameware Controller Trigger Spring Replacement, Replacing Spring: 步骤 4 中的图像 2,2
    • Gently release pressure on the trigger assembly, allowing the components to come apart on your work surface.
    • A new spring may now be incorporated into the designated trigger assembly.
结论
Shoaf
于04/12/22注册
109 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 33
总计 620
