跳转到主内容
Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt
你所需要的
  1. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt, Rear Casing: 步骤 1 中的图像 1,2 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt, Rear Casing: 步骤 1 中的图像 2,2
    • Remove the six Phillips Head 1.2mm screws on the front side of the speaker.
  2. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 步骤 2 中的图像 1,3 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 步骤 2 中的图像 2,3 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 步骤 2 中的图像 3,3
    • Crack open both parts of the casing carefully.
    • Using a plastic opening tool, wedge open the bottom of the speaker to separate the two parts of the speaker.
  3. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 步骤 3 中的图像 1,3 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 步骤 3 中的图像 2,3 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 步骤 3 中的图像 3,3
    • Remove the cooling foam.
    • Use a metal spudger to push the tab in on the red wire.
    • Repeat the process for the blue wire.
  4. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 步骤 4 中的图像 1,2 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 步骤 4 中的图像 2,2
    • The blue wire can now be removed from its connector.
    • Remove the red wire to free the rear casing.
  5. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt, Wiring: 步骤 5 中的图像 1,2 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt, Wiring: 步骤 5 中的图像 2,2
    • Use the metal spudger to bend down the metal tabs that hold the wires to the terminals. The tabs are small and in between the grooves of the terminal.
  6. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 步骤 6 中的图像 1,2 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 步骤 6 中的图像 2,2
    • Remove the wires from the terminals.
  7. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 步骤 7 中的图像 1,2 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 步骤 7 中的图像 2,2
    • Use the metal spudger to bend the metal tabs that hold the connectors to the terminals.
  8. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 步骤 8 中的图像 1,3 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 步骤 8 中的图像 2,3 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 步骤 8 中的图像 3,3
    • Remove the wires from the terminals. Then remove the entire wire assembly.
  9. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt, Front Panel and Speaker Housing: 步骤 9 中的图像 1,1
    • Once the wire assembly is removed, the entire front panel and speaker housing should be separated to replace.
结论
Nick Ruiz
于02/07/17注册
331 声望
创作了3篇指南
团队
USF Tampa, Team 17-3, Blackwell Spring 2017 USF Tampa, Team 17-3, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S17G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 22
总计 1,512
