跳转到主内容
Yamaha FG-425 Guitar String Replacement
你所需要的
  1. Yamaha FG-425 Guitar String Replacement, Guitar String: 步骤 1 中的图像 1,3 Yamaha FG-425 Guitar String Replacement, Guitar String: 步骤 1 中的图像 2,3 Yamaha FG-425 Guitar String Replacement, Guitar String: 步骤 1 中的图像 3,3
    • Turn the tuning peg clockwise using the All-In-1 Restringing Tool’s peg winder to loosen the tension of the strings.
    • Unwind the string from the tuning post and remove the string.
    • Caution: Be careful when removing the string from the tuning post because you may hurt your fingers while doing so.
  2. Yamaha FG-425 Guitar String Replacement: 步骤 2 中的图像 1,2 Yamaha FG-425 Guitar String Replacement: 步骤 2 中的图像 2,2
    • Use the pin remover in the All-In-1 Restringing Tool to remove the pin from the bridge
    • Remove the string from the bridge hole.
  3. Yamaha FG-425 Guitar String Replacement: 步骤 3 中的图像 1,2 Yamaha FG-425 Guitar String Replacement: 步骤 3 中的图像 2,2
    • Bend the string end on the string ball.
    • Place the string into the bridge hole.
  4. Yamaha FG-425 Guitar String Replacement: 步骤 4 中的图像 1,3 Yamaha FG-425 Guitar String Replacement: 步骤 4 中的图像 2,3 Yamaha FG-425 Guitar String Replacement: 步骤 4 中的图像 3,3
    • Place the bridge pin into the bridge hole.
    • Gently pull the string while pushing the pin into the hole.
  5. Yamaha FG-425 Guitar String Replacement: 步骤 5 中的图像 1,2 Yamaha FG-425 Guitar String Replacement: 步骤 5 中的图像 2,2
    • Insert the string through the tuning post hole.
    • Pull the string about half an inch or an inch through the tuning post.
    • Ensure that the string is lined up with the nut.
  6. Yamaha FG-425 Guitar String Replacement: 步骤 6 中的图像 1,1
    • Use the All-In-1 Restringing Tool's peg winder to turn the tuning peg counterclockwise to slightly tighten the strings.
  7. Yamaha FG-425 Guitar String Replacement: 步骤 7 中的图像 1,1
    • Cut any excess strings on the tuning post using the All-In-1 Restringing Tool’s clippers.
终点
另外一个人完成了本指南。
Nicole Francheska Letigio
于01/18/21注册
207 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 12
总计 244
