跳转到主内容
YT-88 Automatic Intelligent Sweeping Robot Full Disassembly
你所需要的
  1. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Starting to Disassemble: 步骤 1 中的图像 1,2 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Starting to Disassemble: 步骤 1 中的图像 2,2
    • Turn the robot vacuum upside down to access the screws underneath.
  2. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the battery: 步骤 2 中的图像 1,3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the battery: 步骤 2 中的图像 2,3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the battery: 步骤 2 中的图像 3,3
    • Using a Phillips 1 screw bit - remove the battery cover and carefully unplug the 18650 rechargeable cell from connector and place it in a safe separate environment along with the battery cover.
  3. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the sweepers: 步骤 3 中的图像 1,3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the sweepers: 步骤 3 中的图像 2,3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the sweepers: 步骤 3 中的图像 3,3
    • Using a Phillips #1 screw bit remove the screws from both of the sweepers and using a slight force or using the shaft of the driver for leverage, remove the sweepers.
  4. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the Top Cover: 步骤 4 中的图像 1,2 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the Top Cover: 步骤 4 中的图像 2,2
    • Using a Phillips #1 driver, remove 6 screws from the base of the vacuum and carefully remove the top cover.
  5. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Disassembling the Top Cover: 步骤 5 中的图像 1,3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Disassembling the Top Cover: 步骤 5 中的图像 2,3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Disassembling the Top Cover: 步骤 5 中的图像 3,3
    • With the top cover now removed we can remove the clipping lid holding the dust box inside which can also be lifted out and removed.
  6. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Tearing down the Dust Box: 步骤 6 中的图像 1,3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Tearing down the Dust Box: 步骤 6 中的图像 2,3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Tearing down the Dust Box: 步骤 6 中的图像 3,3
    • With the dust box removed we can open the latching lid and remove the dust filter by lifting it up from the provided tabs.
  7. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing drive belts: 步骤 7 中的图像 1,1
    • Back in the internals of the vacuum all located in the bottom cover, the sweeper's drive belts can be then removed easily as they have slack - use the shaft of the screw driver if there are difficulties removing them.
  8. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Disconnecting the drive motor, impeller & UV light bar: 步骤 8 中的图像 1,3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Disconnecting the drive motor, impeller & UV light bar: 步骤 8 中的图像 2,3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Disconnecting the drive motor, impeller & UV light bar: 步骤 8 中的图像 3,3
    • Carefully using your fingers, the a flat head screwdriver or recommended tweezers, remove the three JST connectors from the PCB which connect the impeller, drive motor assembly and UV light bar.
  9. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the PCB: 步骤 9 中的图像 1,2 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the PCB: 步骤 9 中的图像 2,2
    • With the PCB now disconnected from the components, the PCB can be removed with a Phillips #1 driver. Put this carefully to one side.
    • Keep in mind the battery connecter needs to be fed through the battery compartment as it is soldered to the board.
  10. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the Impeller Assembly: 步骤 10 中的图像 1,2 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the Impeller Assembly: 步骤 10 中的图像 2,2
    • Using a Phillips #1 driver remove two screws that are holding the impeller assembly to the chassis - you can lift the assembly from the posts.
  11. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the loose parts: 步骤 11 中的图像 1,2 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the loose parts: 步骤 11 中的图像 2,2
    • There are two parts that are loose as they used to be held in by the covers being together.
    • The exhaust cover and fake sensor bar can be lifted up and placed aside.
  12. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the UV light Bar: 步骤 12 中的图像 1,3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the UV light Bar: 步骤 12 中的图像 2,3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the UV light Bar: 步骤 12 中的图像 3,3
    • Using a Phillips #1 driver remove two screws that are holding the UV light bar in place keep this aside.
  13. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Teardown the driver assembly: 步骤 13 中的图像 1,3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Teardown the driver assembly: 步骤 13 中的图像 2,3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Teardown the driver assembly: 步骤 13 中的图像 3,3
    • Using a Phillips #1 driver remove two screws holding the latched cover in place which will reveal the wheels attached to a shaft. You will need to use some tweezers or a flat head driver to carefully release the clips.
  14. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the driving assembly: 步骤 14 中的图像 1,3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the driving assembly: 步骤 14 中的图像 2,3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the driving assembly: 步骤 14 中的图像 3,3
    • Using a Phillips #1 driver remove 4 screws holding the driver motor assembly in place - lift this up and keep it aside.
  15. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the rubber seal: 步骤 15 中的图像 1,2 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the rubber seal: 步骤 15 中的图像 2,2
    • Using a Phillips #1 driver, remove two screws securing the rubber seal that creates a tight seal with the floor for the suction. This can be easily removed from it's location.
  16. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Tearing down the Impeller: 步骤 16 中的图像 1,3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Tearing down the Impeller: 步骤 16 中的图像 2,3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Tearing down the Impeller: 步骤 16 中的图像 3,3
    • The Impeller assembly can be teared down even further for access such as maintenance or cleaning.
    • There are a few plastic clips that need to be carefully unlatched - use a flat head driver or a shim to do this. Take extra caution as some clips might be brittle and will snap with excessive force.
结论
另外一个人完成了本指南。
Frankie Pang
于10/24/24注册
253 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 198
