简介
If you need to replace any of the components within the YCCTEAM YCC-SW4001, you will need to remove the front cover first.
The front cover is an important part of the controller. It includes the ABXY buttons, shoulder buttons, and connects to the back cover via a ribbon cable. This component is often replaced or modified for cosmetic purposes.
Exercise caution when removing the ribbon cable, as there is a component that needs to be carefully moved and can easily be broken.
你所需要的
Use a Phillips #1 screwdriver to remove the eight 9.15 mm screws that secure the back case.
