跳转到主内容
XtremeMac Luna Dock Circuit Board Replacement
你所需要的
  1. XtremeMac Luna Dock Circuit Board Replacement, Bottom Panel: 步骤 1 中的图像 1,3 XtremeMac Luna Dock Circuit Board Replacement, Bottom Panel: 步骤 1 中的图像 2,3 XtremeMac Luna Dock Circuit Board Replacement, Bottom Panel: 步骤 1 中的图像 3,3
    • Flip the device over so that the batteries are closest to you.
    • Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
    • Push the battery against the spring and lift it out of the casing.
    • Repeat with the other battery.
  2. XtremeMac Luna Dock Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Unscrew all eight 12mm Phillips head screws with a Philips #1 screwdriver.
    • The iFixit 26 bit screwdriver kit will not reach the screws. Make sure to use a screwdriver that is thin enough to not get stuck in the screw holes.
  3. XtremeMac Luna Dock Circuit Board Replacement: 步骤 3 中的图像 1,2 XtremeMac Luna Dock Circuit Board Replacement: 步骤 3 中的图像 2,2
    • Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you.
    • Gently tilt the lid back 45 degrees so that the inside is exposed.
    • Be mindful of the wires inside of the Luna. It is easy to break a connection if a wire gets caught.
  4. XtremeMac Luna Dock Circuit Board Replacement, Dock Circuit Board: 步骤 4 中的图像 1,3 XtremeMac Luna Dock Circuit Board Replacement, Dock Circuit Board: 步骤 4 中的图像 2,3 XtremeMac Luna Dock Circuit Board Replacement, Dock Circuit Board: 步骤 4 中的图像 3,3
    • Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case.
结论
Matt Ducasse
于04/18/13注册
12 声望
创作了3篇指南
团队
Cal Poly, Team 3-47, Amido Spring 2013 Cal Poly, Team 3-47, Amido Spring 2013 的会员
CPSU-AMIDO-S13S3G47
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 466
