跳转到主内容
XtremeMac Luna Button Circuit Boards Replacement
你所需要的
  1. XtremeMac Luna Button Circuit Boards Replacement, Bottom Panel: 步骤 1 中的图像 1,3 XtremeMac Luna Button Circuit Boards Replacement, Bottom Panel: 步骤 1 中的图像 2,3 XtremeMac Luna Button Circuit Boards Replacement, Bottom Panel: 步骤 1 中的图像 3,3
    • Flip the device over so that the batteries are closest to you.
    • Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
    • Push the battery against the spring and lift it out of the casing.
    • Repeat with the other battery.
  2. XtremeMac Luna Button Circuit Boards Replacement: 步骤 2 中的图像 1,1
    • Unscrew all eight 12mm Phillips head screws with a Philips #1 screwdriver.
    • The iFixit 26 bit screwdriver kit will not reach the screws. Make sure to use a screwdriver that is thin enough to not get stuck in the screw holes.
  3. XtremeMac Luna Button Circuit Boards Replacement: 步骤 3 中的图像 1,2 XtremeMac Luna Button Circuit Boards Replacement: 步骤 3 中的图像 2,2
    • Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you.
    • Gently tilt the lid back 45 degrees so that the inside is exposed.
    • Be mindful of the wires inside of the Luna. It is easy to break a connection if a wire gets caught.
  4. XtremeMac Luna Button Circuit Boards Replacement, Dock Circuit Board: 步骤 4 中的图像 1,3 XtremeMac Luna Button Circuit Boards Replacement, Dock Circuit Board: 步骤 4 中的图像 2,3 XtremeMac Luna Button Circuit Boards Replacement, Dock Circuit Board: 步骤 4 中的图像 3,3
    • Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case.
  5. XtremeMac Luna Button Circuit Boards Replacement, Button Circuit Boards: 步骤 5 中的图像 1,2 XtremeMac Luna Button Circuit Boards Replacement, Button Circuit Boards: 步骤 5 中的图像 2,2
    • Unscrew the three 7 mm black screws using the Philips #1 screwdriver on the back end of the left and right circuit board.
    • Removing the right circuit board first will make it easier to unscrew the left because the heat-sinks on the left circuit board can get in the way of the screwdriver.
  6. XtremeMac Luna Button Circuit Boards Replacement: 步骤 6 中的图像 1,3 XtremeMac Luna Button Circuit Boards Replacement: 步骤 6 中的图像 2,3 XtremeMac Luna Button Circuit Boards Replacement: 步骤 6 中的图像 3,3
    • Use a plastic opening tool to pry the black connections away from the top casing.
    • Be attentive when you separate the circuit boards from the top, as there is a loose wheel inside.
  7. XtremeMac Luna Button Circuit Boards Replacement: 步骤 7 中的图像 1,2 XtremeMac Luna Button Circuit Boards Replacement: 步骤 7 中的图像 2,2
    • Turn the circuit boards over. Remove the two connections on the left side by pulling on the tabs.
    • The glue that holds the connection together will come off when you pull. Pull on the tab with enough force to break the glue without damaging the wires.
结论
团队
Cal Poly, Team 3-47, Amido Spring 2013 Cal Poly, Team 3-47, Amido Spring 2013 的会员
CPSU-AMIDO-S13S3G47
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 323
