跳转到主内容
Xiaomi Yi Motherboard Replacement
你所需要的
  1. Xiaomi Yi Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Xiaomi Yi Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Push the battery door switch to the left.
    • Lift the battery door up.
  2. Xiaomi Yi Motherboard Replacement: 步骤 2 中的图像 1,3 Xiaomi Yi Motherboard Replacement: 步骤 2 中的图像 2,3 Xiaomi Yi Motherboard Replacement: 步骤 2 中的图像 3,3
    • Lift the battery tab up.
    • Remove the battery by pulling the removal tab.
  3. Xiaomi Yi Motherboard Replacement, Front Panel: 步骤 3 中的图像 1,2 Xiaomi Yi Motherboard Replacement, Front Panel: 步骤 3 中的图像 2,2
    • Introduce the plastic opening tool into any of the sides of the camera.
    • Pry with the plastic opening tool at the seam between the front and the back panel.
  4. Xiaomi Yi Motherboard Replacement: 步骤 4 中的图像 1,3 Xiaomi Yi Motherboard Replacement: 步骤 4 中的图像 2,3 Xiaomi Yi Motherboard Replacement: 步骤 4 中的图像 3,3
    • Slide prying tool along the seam until front panel is fully separated from the back panel.
  5. Xiaomi Yi Motherboard Replacement, Back Panel: 步骤 5 中的图像 1,2 Xiaomi Yi Motherboard Replacement, Back Panel: 步骤 5 中的图像 2,2
    • Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
  6. Xiaomi Yi Motherboard Replacement: 步骤 6 中的图像 1,3 Xiaomi Yi Motherboard Replacement: 步骤 6 中的图像 2,3 Xiaomi Yi Motherboard Replacement: 步骤 6 中的图像 3,3
    • Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside.
  7. Xiaomi Yi Motherboard Replacement: 步骤 7 中的图像 1,2 Xiaomi Yi Motherboard Replacement: 步骤 7 中的图像 2,2
    • Remove the motherboard from from the back case by gently pulling on the lens housing.
    • Back panel remains.
  8. Xiaomi Yi Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,2 Xiaomi Yi Motherboard Replacement, Motherboard: 步骤 8 中的图像 2,2
    • Remove the two 3.1 mm Phillips #000 screws securing the motherboard to the chassis.
    • Be sure to support the motherboard, the ribbon cable connection can easily be damaged.
  9. Xiaomi Yi Motherboard Replacement: 步骤 9 中的图像 1,3 Xiaomi Yi Motherboard Replacement: 步骤 9 中的图像 2,3 Xiaomi Yi Motherboard Replacement: 步骤 9 中的图像 3,3
    • Locate the rubber spacer between the image sensor and the ribbon connection for the motherboard.
    • Using the tweezers gently remove the spacer block and set aside.
  10. Xiaomi Yi Motherboard Replacement: 步骤 10 中的图像 1,2 Xiaomi Yi Motherboard Replacement: 步骤 10 中的图像 2,2
    • Pry gently using the flat end of the black spudger to remove the ribbon connector.
    • Lift the lens assembly up and away from the motherboard.
    • Motherboard remains.
结论
11等其他人完成本指南。
团队
USF Tampa, Team 15-5, Blackwell Fall 2015 USF Tampa, Team 15-5, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S15G5
3 名成员
创作了10篇指南
8条评论
Where you buy motherboard for xiaomi yi ?
diamond1981 - 回复
I wonder where I can buy this part ribbon connector to buy.
viilelaa - 回复
Link for buying it waaaaaaaay cheaper:http://bit.ly/XiaoMiYi1080P
tozilen - 回复
Great guide but useless, there is no spare parts on the market for this camera
Nebojsa Rosic - 回复
IC repair is always possible
AdamA -
Has someone found where to buy spare parts? Or damaged camera?
Toni - 回复
Any idea where I could buy parts for this camera? Has anyone managed to find any parts on the market?
Lothar Krupka - 回复
where is ic power ??
Hafiz Darsy - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 17
总计 12,232
