跳转到主内容
简介
If the audio in your recordings is distorted or missing, you may consider replacing the microphone. This guide will show you how to open the Xiaomi Yi and locate the microphone for replacement.
  1. Push the battery door switch to the left. Lift the battery door up.
    • Push the battery door switch to the left.
    • Lift the battery door up.
  2. Lift the battery tab up. Remove the battery by pulling the removal tab. Remove the battery by pulling the removal tab.
    • Lift the battery tab up.
    • Remove the battery by pulling the removal tab.
  3. Introduce the plastic opening tool into any of the sides of the camera. Pry with the plastic opening tool at the seam between the front and the back panel.
    • Introduce the plastic opening tool into any of the sides of the camera.
    • Pry with the plastic opening tool at the seam between the front and the back panel.
  4. Slide  prying tool along the seam until front panel is fully separated from the back panel. Slide  prying tool along the seam until front panel is fully separated from the back panel. Slide  prying tool along the seam until front panel is fully separated from the back panel.
    • Slide prying tool along the seam until front panel is fully separated from the back panel.
  5. Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard. Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
    • Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
  6. Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside. Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside. Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside.
    • Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside.
  7. Remove the motherboard from from the back case by gently pulling on the lens housing. Back panel remains.
    • Remove the motherboard from from the back case by gently pulling on the lens housing.
    • Back panel remains.
  8. Locate the solder points connected to the red and black wire on the back of the motherboard. Locate the solder points connected to the red and black wire on the back of the motherboard.
    • Locate the solder points connected to the red and black wire on the back of the motherboard.
  9. Heat these two points with a Soldering Iron and remove the microphone. Reapply fresh solder with the replacement microphone.
    • Heat these two points with a Soldering Iron and remove the microphone. Reapply fresh solder with the replacement microphone.
    • Soldering Irons are very hot and fumes from melted solder can cause irritation. Use only in a clean, well ventilated area.
结论
12等其他人完成本指南。
Matt Bibby
于2015年08月26日注册
492 信誉积分
撰写一个指南
团队
USF Tampa, Team 15-5, Blackwell Fall 2015 USF Tampa, Team 15-5, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S15G5
3 名成员
创作了10篇指南
My camera came with the microphone not soldered at all (two microphone wires were hanging above the motherboard with no sign of soldering).
That was an easy repair as soon as I figured out what's the culprit, but before I've blamed the software for this issue for two days and tinkered with the software for at least 6 hours with no result.
adryjanowski, very nice tutorial, thank you!
Ivan Elizarov - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 13
总计 7,307
