跳转到主内容
Xiaomi Yi Front Panel Replacement
你所需要的
  1. Xiaomi Yi Front Panel Replacement, Battery: 步骤 1 中的图像 1,2 Xiaomi Yi Front Panel Replacement, Battery: 步骤 1 中的图像 2,2
    • Push the battery door switch to the left.
    • Lift the battery door up.
  2. Xiaomi Yi Front Panel Replacement: 步骤 2 中的图像 1,3 Xiaomi Yi Front Panel Replacement: 步骤 2 中的图像 2,3 Xiaomi Yi Front Panel Replacement: 步骤 2 中的图像 3,3
    • Lift the battery tab up.
    • Remove the battery by pulling the removal tab.
  3. Xiaomi Yi Front Panel Replacement, Front Panel: 步骤 3 中的图像 1,2 Xiaomi Yi Front Panel Replacement, Front Panel: 步骤 3 中的图像 2,2
    • Introduce the plastic opening tool into any of the sides of the camera.
    • Pry with the plastic opening tool at the seam between the front and the back panel.
  4. Xiaomi Yi Front Panel Replacement: 步骤 4 中的图像 1,3 Xiaomi Yi Front Panel Replacement: 步骤 4 中的图像 2,3 Xiaomi Yi Front Panel Replacement: 步骤 4 中的图像 3,3
    • Slide prying tool along the seam until front panel is fully separated from the back panel.
结论
5等其他人完成本指南。
团队
USF Tampa, Team 15-5, Blackwell Fall 2015 USF Tampa, Team 15-5, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S15G5
3 名成员
创作了10篇指南
3条评论
Where do you get a spare front panel, the small plastic hooks break easily
ltkipras - 回复
I would like to know too because i had a crash and i lost the ring that goes around the lens.
fabiocastroam -
For what is the black Strip with the gold plated contact on the front panel? Is that a check for installated front panel, and can i fake them for an replacement panel?
shguro - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 2,817
