本指南有最近更改,您可查看未经巡查的最新版本。
简介
If your camera's back case is damaged, you might consider changing it. To remove the back panel you will need a small blue plastic opening tool.
你所需要的
Introduce the plastic opening tool into any of the sides of the camera.
Pry with the plastic opening tool at the seam between the front and the back panel.
Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
10等其他人完成本指南。
2条评论
Where can i buy the back panel replacement ?
