跳转到主内容
Xiaomi Redmi Note Front-Facing Camera Replacement
你所需要的
  1. Xiaomi Redmi Note Front-Facing Camera Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
  2. Xiaomi Redmi Note Front-Facing Camera Replacement: 步骤 2 中的图像 1,2 Xiaomi Redmi Note Front-Facing Camera Replacement: 步骤 2 中的图像 2,2
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
  3. Xiaomi Redmi Note Front-Facing Camera Replacement: 步骤 3 中的图像 1,2 Xiaomi Redmi Note Front-Facing Camera Replacement: 步骤 3 中的图像 2,2
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
  4. Xiaomi Redmi Note Front-Facing Camera Replacement, Midframe: 步骤 4 中的图像 1,2 Xiaomi Redmi Note Front-Facing Camera Replacement, Midframe: 步骤 4 中的图像 2,2
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
  5. Xiaomi Redmi Note Front-Facing Camera Replacement: 步骤 5 中的图像 1,2 Xiaomi Redmi Note Front-Facing Camera Replacement: 步骤 5 中的图像 2,2
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
  6. Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: 步骤 6 中的图像 1,3 Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: 步骤 6 中的图像 2,3 Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position.
    • Use tweezers to pull the ribbon cable out of the ZIF connector.
    • Remove the front-facing camera from the motherboard.
结论
2等其他人完成本指南。
Caitlin Settles
于04/26/17注册
789 声望
创作了2篇指南
团队
Cal Poly, Team S22-G4, Livingston Spring 2017 Cal Poly, Team S22-G4, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S22G4
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 24
总计 1,763
