跳转到主内容
加入维修社区 - 创建账户
Xiaomi Redmi Note 3 Disassembly Guide
你所需要的
  1. Xiaomi Redmi Note 3 Disassembly Guide, Eject the Sim Card Tray: 步骤 1 中的图像 1,2 Xiaomi Redmi Note 3 Disassembly Guide, Eject the Sim Card Tray: 步骤 1 中的图像 2,2
    • Locate the sim card tray at the right side of the phone
    • Insert the metal needle sim tool into the tray hole to eject the tray and pull it out
  2. Xiaomi Redmi Note 3 Disassembly Guide, Remove Phone Panel: 步骤 2 中的图像 1,1
    • Insert your thumb in between the back panel and the front of phone and slowly follow along the edges to separate the two pieces
  3. Xiaomi Redmi Note 3 Disassembly Guide, Disconnect the Connector: 步骤 3 中的图像 1,1
    • Remove the plastic connector that links the battery with the motherboard by gently prying the ends of the connector from each side of the phone
  4. Xiaomi Redmi Note 3 Disassembly Guide, Begin Battery Removal: 步骤 4 中的图像 1,1
    • Pull the black tab at the top left of the battery to disconnect the battery from the system
  5. Xiaomi Redmi Note 3 Disassembly Guide, Remove Battery: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Wedge the tweezers under the battery to lift it up
    • Remove as much as adhesive as needed to lift the battery from phone using tweezers or fingers
    • Adhesive that binds the battery to the phone can be strong and this may require a little bit of effort to remove the battery
  6. Xiaomi Redmi Note 3 Disassembly Guide, Unscrew Speaker: 步骤 6 中的图像 1,1
    • Use the screwdriver to unscrew the speaker at the bottom back of the phone. There are five screws around the edges of the speaker
  7. Xiaomi Redmi Note 3 Disassembly Guide, Detach Speaker: 步骤 7 中的图像 1,1
    • Remove the loud speaker cover using the tweezers to expose the daughterboard
  8. Xiaomi Redmi Note 3 Disassembly Guide, Remove Daughterboard: 步骤 8 中的图像 1,2 Xiaomi Redmi Note 3 Disassembly Guide, Remove Daughterboard: 步骤 8 中的图像 2,2
    • Remove the two gold tabs on the two top corners of the daughterboard
    • Pry the daughterboard open with the tweezers or pull it out using your fingers
    • There is a heat shield underneath the daughter board and it can get hot from charging the phone so make sure you don’t touch it
  9. Xiaomi Redmi Note 3 Disassembly Guide, Begin to Remove Camera: 步骤 9 中的图像 1,1
    • Unscrew the four screws at the top of the motherboard and pop up the top cover
    • One screw might by disguised by a sticker so locate that and remove the sticker as well
    • Pulling the top cover without removing all the screws might damage the motherboard
  10. Xiaomi Redmi Note 3 Disassembly Guide, Remove Camera Cushion: 步骤 10 中的图像 1,1
    • Remove the rubber cover that’s containing the camera
  11. Xiaomi Redmi Note 3 Disassembly Guide, Remove Front Camera Protector: 步骤 11 中的图像 1,1
    • Pull the tab that’s holding the front camera to remove the camera protector
    • To keep the camera from damage hold the camera from the corner and not from the middle of it
  12. Xiaomi Redmi Note 3 Disassembly Guide, Remove Camera: 步骤 12 中的图像 1,1
    • Pull out the front camera using tweezers or your fingers
  13. Xiaomi Redmi Note 3 Disassembly Guide, Remove Motherboard Connectors: 步骤 13 中的图像 1,1
    • Remove the five connectors of the motherboard using tweezers or your fingers
  14. Xiaomi Redmi Note 3 Disassembly Guide, Remove Motherboard: 步骤 14 中的图像 1,1
    • Remove the remaining four screws as your work down to the bottom to loosen the motherboard
  15. Xiaomi Redmi Note 3 Disassembly Guide, Admire Disassembled Phone: 步骤 15 中的图像 1,1
    • Congrats -- You disassembled the Xiaomi Redmi Note 3!
结论
Meaghan Owens
于06/23/23注册
241 声望
撰写一个指南
1指南评论
Memory ic problem
Sure - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 39
总计 1,621
