简介
Use this guide to remove the screen assembly of your Xiaomi Redmi 2 for repair or replacement of any parts attached.
你所需要的
Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
pull up the black plastic part of this conector to free the ribbon before remove! this step is missing!!!!
Thanks Rodrigo, saved me!
Rodrigo -
Using the nylon or metal spudger, gently pry the front speaker from the screen assembly.
Using your fingers, gently lift the front speaker from the screen assembly.
Thanks. I was replacing a friend's digitizer, and in the process, broke the speaker (they come apart very easily). So I decided to replace her broken speaker with mine (we both have a Note 2). Then I broke MINE taking it out. So now I have to order two new speakers. Arggghhh.
Rademi 2 back Spekar
Amol Surve - 回复
Sar rademi 2 front Speakers probably
Amol Surve - 回复
Remove the 2.9 mm Phillips #000 screw that holds the PCB circuit board to the screen assembly.
Carefully lift the PCB circuit board from the screen assembly and set aside.
The screen assembly is pictured to the left of the circuit board and is now ready for repair or replacement.
31等其他人完成本指南。
2条评论
Touch is not working after replacing full LCD, Brought new display & changed again but no luck, Display is okay but touch not working.
That's unnecessary. The cover itself has a small notch on it to remove it to the left
Mad Max - 回复
