跳转到主内容
Xiaomi Redmi 2 Screen Assembly Replacement
你所需要的
  1. Xiaomi Redmi 2 Screen Assembly Replacement, Motherboard: 步骤 1 中的图像 1,2 Xiaomi Redmi 2 Screen Assembly Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
  2. Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 2 中的图像 1,1
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 4 中的图像 1,1
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 5 中的图像 1,1
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 6 中的图像 1,2 Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 7 中的图像 1,2 Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 7 中的图像 2,2
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
  8. Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 8 中的图像 1,2 Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 8 中的图像 2,2
    • Lift and hinge the motherboard with your fingers.
  9. Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 9 中的图像 1,2 Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 9 中的图像 2,2
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 10 中的图像 1,2 Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 10 中的图像 2,2
    • Using the tweezers, pull the antenna connector from the motherboard.
  11. Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 11 中的图像 1,1
    • Lift the motherboard out of the front cover and set aside.
  12. Xiaomi Redmi 2 Screen Assembly Replacement, Front Speaker: 步骤 12 中的图像 1,1
    • Using the nylon or metal spudger, gently pry the front speaker from the screen assembly.
  13. Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 13 中的图像 1,1
    • Using your fingers, gently lift the front speaker from the screen assembly.
  14. Xiaomi Redmi 2 Screen Assembly Replacement, PCB Circuit Board: 步骤 14 中的图像 1,1
    • Remove the 2.9 mm Phillips #000 screw that holds the PCB circuit board to the screen assembly.
  15. Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 15 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using the tweezers, lift the antenna connector from the PCB circuit board.
  16. Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 16 中的图像 1,2 Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 16 中的图像 2,2
    • Do not remove the PCB circuit board at this time.
    • Using the nylon or metal spudger, gently pry back the top of the PCB circuit board from the screen assembly.
  17. Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 17 中的图像 1,1
    • Using the nylon or metal spudger, pry back the silver clip covering the ribbon connector.
  18. Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 18 中的图像 1,2 Xiaomi Redmi 2 Screen Assembly Replacement: 步骤 18 中的图像 2,2
    • Carefully lift the PCB circuit board from the screen assembly and set aside.
    • The screen assembly is pictured to the left of the circuit board and is now ready for repair or replacement.
结论
31等其他人完成本指南。
Alicia Brenner
于10/01/15注册
3,539 声望
创作了5篇指南
团队
USF Tampa, Team 1-3, Leahy Fall 2015 USF Tampa, Team 1-3, Leahy Fall 2015 的会员
USFT-LEAHY-F15S1G3
2 名成员
创作了5篇指南
2条评论
ok so good is can service nice
SAFUTRA - 回复
Touch is not working after replacing full LCD, Brought new display & changed again but no luck, Display is okay but touch not working.
Rajesh Gopisetti - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 29
总计 17,433
