跳转到主内容
  1. 这个步骤还没有翻译 帮忙翻译一下
    Use the flat end of the spudger to remove the back panel from the mid-frame and front body. Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
  2. 这个步骤还没有翻译 帮忙翻译一下
    Insert your finger into the curved opening of the mid-frame.
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. 这个步骤还没有翻译 帮忙翻译一下
    Remove the SIM and/or memory cards if present.
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. 这个步骤还没有翻译 帮忙翻译一下
    Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. 这个步骤还没有翻译 帮忙翻译一下
    Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. 这个步骤还没有翻译 帮忙翻译一下
    Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector. Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. 这个步骤还没有翻译 帮忙翻译一下
    Using one prong of the tweezers, pry the ribbon clip away from the motherboard. Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
  8. 这个步骤还没有翻译 帮忙翻译一下
    Lift and  hinge the motherboard with your fingers. Lift and  hinge the motherboard with your fingers.
    • Lift and hinge the motherboard with your fingers.
  9. 这个步骤还没有翻译 帮忙翻译一下
    Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector. Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. 这个步骤还没有翻译 帮忙翻译一下
    Using the tweezers, pull the antenna connector from the motherboard. Using the tweezers, pull the antenna connector from the motherboard.
    • Using the tweezers, pull the antenna connector from the motherboard.
  11. 这个步骤还没有翻译 帮忙翻译一下
    Lift the motherboard out of the front cover and set aside.
    • Lift the motherboard out of the front cover and set aside.
终点
45等其他人完成本指南。
Alicia Brenner
于2015年10月01日注册
3,491 信誉积分
创作了5篇指南
团队
USF Tampa, Team 1-3, Leahy Fall 2015 USF Tampa, Team 1-3, Leahy Fall 2015 的会员
USFT-LEAHY-F15S1G3
2 名成员
创作了5篇指南
17条评论
this is very helpful
Ana - 回复
hi brother mi phone was water damaged .it was not wrking i mean phone gets on but no display. phone gets ring and i can lift call and speak. when i connect to laptop i can access files in it. its get charging on connecting to charger
can u suggest me wat to do
please
asreefbashak - 回复
may be LCD is damage. can fix it at 82877181 contact Peter for checking.
netman91 -
Hi bro I'm having redmi 2 mobile and it has a problem it is not taking any os it's having a compliant of not receiving os .....
There is any solution for that
Please give me reply bro any suggestions
jhon Carter - 回复
Can i know the name of the motherboard used for redmi 2 prime 16GB,please tell me the name bro
Jakka Akhilesh - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 5
过去的30天: 34
总计 34,211
