跳转到主内容
Xiaomi Redmi 2 Front Speaker Replacement
你所需要的
  1. Xiaomi Redmi 2 Front Speaker Replacement, Motherboard: 步骤 1 中的图像 1,2 Xiaomi Redmi 2 Front Speaker Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
  2. Xiaomi Redmi 2 Front Speaker Replacement: 步骤 2 中的图像 1,1
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. Xiaomi Redmi 2 Front Speaker Replacement: 步骤 3 中的图像 1,1
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. Xiaomi Redmi 2 Front Speaker Replacement: 步骤 4 中的图像 1,1
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. Xiaomi Redmi 2 Front Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. Xiaomi Redmi 2 Front Speaker Replacement: 步骤 6 中的图像 1,2 Xiaomi Redmi 2 Front Speaker Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. Xiaomi Redmi 2 Front Speaker Replacement: 步骤 7 中的图像 1,2 Xiaomi Redmi 2 Front Speaker Replacement: 步骤 7 中的图像 2,2
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
  8. Xiaomi Redmi 2 Front Speaker Replacement: 步骤 8 中的图像 1,2 Xiaomi Redmi 2 Front Speaker Replacement: 步骤 8 中的图像 2,2
    • Lift and hinge the motherboard with your fingers.
  9. Xiaomi Redmi 2 Front Speaker Replacement: 步骤 9 中的图像 1,2 Xiaomi Redmi 2 Front Speaker Replacement: 步骤 9 中的图像 2,2
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. Xiaomi Redmi 2 Front Speaker Replacement: 步骤 10 中的图像 1,2 Xiaomi Redmi 2 Front Speaker Replacement: 步骤 10 中的图像 2,2
    • Using the tweezers, pull the antenna connector from the motherboard.
  11. Xiaomi Redmi 2 Front Speaker Replacement: 步骤 11 中的图像 1,1
    • Lift the motherboard out of the front cover and set aside.
  12. Xiaomi Redmi 2 Front Speaker Replacement, Front Speaker: 步骤 12 中的图像 1,1
    • Using the nylon or metal spudger, gently pry the front speaker from the screen assembly.
  13. Xiaomi Redmi 2 Front Speaker Replacement: 步骤 13 中的图像 1,1
    • Using your fingers, gently lift the front speaker from the screen assembly.
结论
7等其他人完成本指南。
Alicia Brenner
于10/01/15注册
3,539 声望
创作了5篇指南
团队
USF Tampa, Team 1-3, Leahy Fall 2015 USF Tampa, Team 1-3, Leahy Fall 2015 的会员
USFT-LEAHY-F15S1G3
2 名成员
创作了5篇指南
4条评论
How can I remove the contact from the speaker? I bought a new screen and it hasn't this contact and the vibracall module, but the second I know how to remove from the old screen.
brunofichos - 回复
sorry about my english, I want to say "back speaker's contact" not "contact from the speaker". Thanks
brunofichos -
You know how to remove the speaker contacts from the rear speaker. It's stuck in the redmi2pro frame. I bought an LCD touch frame and need to move the components to the new one.
afreitasleonardo - 回复
Rademi 2 front Speakers problem
Amol Surve - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 7,088
