跳转到主内容
Xiaomi Mi Pad Motherboard Replacement
你所需要的
  1. Xiaomi Mi Pad Motherboard Replacement, Rear Case Assembly: 步骤 1 中的图像 1,1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Motherboard Replacement: 步骤 2 中的图像 1,2 Xiaomi Mi Pad Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,2 Xiaomi Mi Pad Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Remove the twelve 3 mm Phillips #00 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the two 3.0 mm Phillips #00 screws securing the motherboard to the device.
  6. Xiaomi Mi Pad Motherboard Replacement: 步骤 6 中的图像 1,2 Xiaomi Mi Pad Motherboard Replacement: 步骤 6 中的图像 2,2
    • Disconnect the six ribbon cables attached to the motherboard using a plastic opening tool.
  7. Xiaomi Mi Pad Motherboard Replacement: 步骤 7 中的图像 1,1
    • Carefully remove the motherboard from the device.
    How to get new one mother board
    MSK DIGITAL MEDIA - 回复
    Pls help me service company saying to me it's motherboard crashed
    I wants new on on low price
    How to get new one of this mi pad mother board
    This is my email sunilhpt90@gmail. com
    Sunil - 回复
结论
12等其他人完成本指南。
Kiefer Sivitz
于09/03/15注册
560 声望
创作了3篇指南
团队
USF Tampa, Team 12-5, Blackwell Fall 2015 USF Tampa, Team 12-5, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S12G5
3 名成员
创作了13篇指南
4条评论
It's my email
amaank987321.msk@gmail.com
i'm looking to buy a motherboard for my died mi pad and i couldn't find it any were. Do you know were i can bay one , please help
Vasile Postolache - 回复
I want mi pad mother board
Where I buy
Sunil - 回复
where can i buy matherboard for Xiaomi Mi Pad 4 ?
guyv1975 - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 48
总计 6,582
