跳转到主内容
Xiaomi Mi Pad Headphone Jack Replacement
你所需要的
  1. Xiaomi Mi Pad Headphone Jack Replacement, Rear Case Assembly: 步骤 1 中的图像 1,1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Headphone Jack Replacement: 步骤 2 中的图像 1,2 Xiaomi Mi Pad Headphone Jack Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Headphone Jack Replacement, Headphone Jack: 步骤 3 中的图像 1,2 Xiaomi Mi Pad Headphone Jack Replacement, Headphone Jack: 步骤 3 中的图像 2,2
    • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Headphone Jack Replacement: 步骤 4 中的图像 1,1
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Headphone Jack Replacement: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to pull up and remove the headphone jack from the upper cover.
    • Insert the corner of a plastic opening tool into the port of the headphone jack for easier removal.
结论
另外一个人完成了本指南。
Rene Mendoza
于09/03/15注册
311 声望
创作了2篇指南
团队
USF Tampa, Team 12-5, Blackwell Fall 2015 USF Tampa, Team 12-5, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S12G5
3 名成员
创作了13篇指南
一条评论
And where to buy? :-(
marcusvoag - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 2,439
