跳转到主内容
Xiaomi Mi Pad Battery Replacement
你所需要的
  1. Xiaomi Mi Pad Battery Replacement, Rear Case Assembly: 步骤 1 中的图像 1,1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Battery Replacement: 步骤 2 中的图像 1,2 Xiaomi Mi Pad Battery Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Battery Replacement, Battery: 步骤 3 中的图像 1,2 Xiaomi Mi Pad Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Battery Replacement: 步骤 5 中的图像 1,2 Xiaomi Mi Pad Battery Replacement: 步骤 5 中的图像 2,2
    • Use a plastic opening tool to disconnect the three ribbon cable connectors.
    • If you're only going to replace the battery, you should only need to disconnect the smallest ribbon cable that connects the battery to the motherboard.
  6. Xiaomi Mi Pad Battery Replacement: 步骤 6 中的图像 1,1
    • Carefully pry around the perimeter of the battery with a plastic opening tool to loosen the adhesive securing the battery to the device.
    • Be gentle when removing the battery, as lithium-ion batteries should not be bent or punctured.
  7. Xiaomi Mi Pad Battery Replacement: 步骤 7 中的图像 1,3 Xiaomi Mi Pad Battery Replacement: 步骤 7 中的图像 2,3 Xiaomi Mi Pad Battery Replacement: 步骤 7 中的图像 3,3
    • If you disconnected all three connectors, the charging port ribbon cable may have a small amount of adhesive securing it to the battery. Gently pry the cable free of the battery and lift the battery up and out of the device.
结论
18等其他人完成本指南。
Jessica
于09/03/15注册
713 声望
撰写一个指南
团队
USF Tampa, Team 12-5, Blackwell Fall 2015 USF Tampa, Team 12-5, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S12G5
3 名成员
创作了13篇指南
12条评论
Hi
Great Tutorial, but where can i buy a replacement Battery?
THANKS
Marcel - 回复
Go to Leamington road and you will get it
affan -
Go to Leamington road mumbai
affan -
Where to purchase the Mi Paf battery?
Dino Bay - 回复
Please please make a video for it. I need it desperately.
Man Mohan Shukla - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 26
过去 30 天: 125
总计 23,565
