跳转到主内容
Xiaomi Mi Note Battery Replacement
你所需要的
  1. Xiaomi Mi Note Battery Replacement, Battery: 步骤 1 中的图像 1,2 Xiaomi Mi Note Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
  2. Xiaomi Mi Note Battery Replacement: 步骤 2 中的图像 1,3 Xiaomi Mi Note Battery Replacement: 步骤 2 中的图像 2,3 Xiaomi Mi Note Battery Replacement: 步骤 2 中的图像 3,3
    • Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
    • Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
    • Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
    • Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
  3. Xiaomi Mi Note Battery Replacement: 步骤 3 中的图像 1,1
    • Use a nylon spudger to pry upwards to detach the ribbon that's connecting the battery to the motherboard.
  4. Xiaomi Mi Note Battery Replacement: 步骤 4 中的图像 1,2 Xiaomi Mi Note Battery Replacement: 步骤 4 中的图像 2,2
    • Insert a nylon or metal spudger underneath the battery at any point. Then slide the spudger around all the edges to loosen it. The battery can now be easily lifted out of the frame.
    • Glue will be holding down the backside of the battery.
结论
15等其他人完成本指南。
Mark Sears
于08/27/15注册
1,231 声望
创作了4篇指南
团队
USF Tampa, Team 1-6, Sullivan Fall 2015 USF Tampa, Team 1-6, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S1G6
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 92
总计 36,932
