简介
This guide will show how to remove and replace the front facing camera on the Xiaomi Mi A2 Smartphone. Make sure during this replacement that you are being very precise while following each step exactly because if you miss a step, it will be hard for you to catch back up with your progress.
你所需要的
Grab a suction cup tool and place it near the bottom of the phone.
Pull up on the suction cup to slightly lift the LCD Panel from the body of the phone.
Starting from the bottom, slide in a plastic opening tool between the gap of the LCD and the phone.
Using a combination of the plastic opening tool and picks, slide around the gaps to unhook the clips, unhinging the panel from the body of the phone.
Flip the phone screen towards the bottom of the device and lay the screen facing down.
Using a plastic spudger remove the battery connector ribbon cable by getting underneath the connector and gently lifting it off.
Using a plastic sudger remove the screen connector ribbon cable by lifting from the underneath.
After you remove the ribbon cable the panel should be free to remove and replace.
On the bottom of the battery are two pull tabs. They are glued on to the battery similarly like a sticker.
To remove the battery pull these pull tabs downwards. WARNING: proceed with extreme caution, avoid bending or puncturing the battery.
You can use tweezers to lift the pull tabs from the battery. Pull downwards and the adhesive will slowly be removed from the battery.
Using a plastic spudger, gently separate the front camera ribbon cable from the motherboard.
另外一个人完成了本指南。
