跳转到主内容
Xiaomi Mi 9 Front Camera Replacement
你所需要的
  1. Xiaomi Mi 9 Front Camera Replacement, Rear Glass: 步骤 1 中的图像 1,1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
  2. Xiaomi Mi 9 Front Camera Replacement: 步骤 2 中的图像 1,3 Xiaomi Mi 9 Front Camera Replacement: 步骤 2 中的图像 2,3 Xiaomi Mi 9 Front Camera Replacement: 步骤 2 中的图像 3,3
    • Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a gap between the glass and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner of the phone.
  3. Xiaomi Mi 9 Front Camera Replacement: 步骤 3 中的图像 1,2 Xiaomi Mi 9 Front Camera Replacement: 步骤 3 中的图像 2,2
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Xiaomi Mi 9 Front Camera Replacement: 步骤 4 中的图像 1,3 Xiaomi Mi 9 Front Camera Replacement: 步骤 4 中的图像 2,3 Xiaomi Mi 9 Front Camera Replacement: 步骤 4 中的图像 3,3
    • Insert a third opening pick at the bottom left corner.
    • Start to slide the opening pick from the bottom left corner along the side of the Xiaomi Mi 9 to cut the adhesive.
    • Be aware of the rear cameras and only insert the tip of the opening pick. As the adhesive cools down it gets harder to cut. If necessary use your iOpener to reheat it.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Xiaomi Mi 9 Front Camera Replacement: 步骤 5 中的图像 1,2 Xiaomi Mi 9 Front Camera Replacement: 步骤 5 中的图像 2,2
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    Be very careful at this point not to raise the cover too much, at the slightest bending the glass shatters. It just happened to me :(
    enrica_spiga - 回复
  6. Xiaomi Mi 9 Front Camera Replacement: 步骤 6 中的图像 1,2 Xiaomi Mi 9 Front Camera Replacement: 步骤 6 中的图像 2,2
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right edge to cut the remaining adhesive.
  7. Xiaomi Mi 9 Front Camera Replacement: 步骤 7 中的图像 1,2 Xiaomi Mi 9 Front Camera Replacement: 步骤 7 中的图像 2,2
    • Carefully lift the rear glass and remove it.
    • Before installing new adhesive and reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    Il y a un peu d'adhésif autour de l'appareil photo, c'est pour cela que ça peu forcer un tout petit peu.
    Charles - 回复
  8. Xiaomi Mi 9 Front Camera Replacement, Motherboard Cover with Charging Coil: 步骤 8 中的图像 1,1
    • Remove the ten Phillips #00 screws (3 mm length) that secure the motherboard cover.
    • There might be tamper proof sticker on some of the screws.
    Note, the Explorer/Transparent edition does not use phillips #00 screws.
    Jason Baginski - 回复
    It uses 0.8mm star screws(P2 Pentalobe in the iFixIt store)
    Jason Baginski -
    Thanks for mentioning Jason!
    Dominik Schnabelrauch -
  9. Xiaomi Mi 9 Front Camera Replacement: 步骤 9 中的图像 1,2 Xiaomi Mi 9 Front Camera Replacement: 步骤 9 中的图像 2,2
    • Insert an opening pick at the top right corner of the motherboard cover.
    • Twist the opening pick sideways to pry up and slightly lift the motherboard cover.
  10. Xiaomi Mi 9 Front Camera Replacement: 步骤 10 中的图像 1,2 Xiaomi Mi 9 Front Camera Replacement: 步骤 10 中的图像 2,2
    • Carefully remove the motherboard cover including the charging coil / NFC antenna.
  11. Xiaomi Mi 9 Front Camera Replacement, Battery Disconnect: 步骤 11 中的图像 1,2 Xiaomi Mi 9 Front Camera Replacement, Battery Disconnect: 步骤 11 中的图像 2,2
    • Use a spudger to pry up and disconnect the battery flex cable.
  12. Xiaomi Mi 9 Front Camera Replacement, Front Facing Camera: 步骤 12 中的图像 1,2 Xiaomi Mi 9 Front Camera Replacement, Front Facing Camera: 步骤 12 中的图像 2,2
    • Use a pair of tweezers to pell the copper tape off the motherboard and fold it out of the way.
  13. Xiaomi Mi 9 Front Camera Replacement: 步骤 13 中的图像 1,2 Xiaomi Mi 9 Front Camera Replacement: 步骤 13 中的图像 2,2
    • Use the flat end of a spudger to pry up and disconnect the flex cable of the front camera.
  14. Xiaomi Mi 9 Front Camera Replacement: 步骤 14 中的图像 1,2 Xiaomi Mi 9 Front Camera Replacement: 步骤 14 中的图像 2,2
    • Use a pair of tweezers to lift the front camera out of its recess and remove it.
结论
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
另外一个人完成了本指南。
于11/23/16注册
203,329 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
4条评论
Can you suggest a replacement Front camera where I can purchase?
Manoj kumar - 回复
Muchísimas gracias por la guía. Pude Limpiar la cámara frontal sin ningún problema.
Naomi Díaz - 回复
Hello,
is there also a possibility to exchange a display on a Mi9?
Best Regards
Frank
Frank Michel - 回复
Hi Frank,
this AMOLED & Digitizer guide might be the one you’re looking for.
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 46
总计 2,859
