跳转到主内容
Xiaomi Mi 4 Rear Case/Midframe Replacement
你所需要的
  1. Xiaomi Mi 4 Rear Case/Midframe Replacement, Rear Case/Midframe: 步骤 1 中的图像 1,3 Xiaomi Mi 4 Rear Case/Midframe Replacement, Rear Case/Midframe: 步骤 1 中的图像 2,3 Xiaomi Mi 4 Rear Case/Midframe Replacement, Rear Case/Midframe: 步骤 1 中的图像 3,3
    • Check to make sure that the device is powered off.
    • Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
    • Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
  2. Xiaomi Mi 4 Rear Case/Midframe Replacement: 步骤 2 中的图像 1,3 Xiaomi Mi 4 Rear Case/Midframe Replacement: 步骤 2 中的图像 2,3 Xiaomi Mi 4 Rear Case/Midframe Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Metal Spudger
    $2.99
    购买
    • Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
    • Using the second spudger, slowly work your way around the perimeter of the device
    • Listen for clicking sounds as you are prying the back cover away from the frame
    • As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
  3. Xiaomi Mi 4 Rear Case/Midframe Replacement: 步骤 3 中的图像 1,3 Xiaomi Mi 4 Rear Case/Midframe Replacement: 步骤 3 中的图像 2,3 Xiaomi Mi 4 Rear Case/Midframe Replacement: 步骤 3 中的图像 3,3
    • Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
结论
9等其他人完成本指南。
Robert Cobaich
于09/03/15注册
2,073 声望
创作了3篇指南
团队
USF Tampa, Team 16-1, Blackwell Winter 2016 USF Tampa, Team 16-1, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S16G1
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 14
总计 4,269
