跳转到主内容
Xiaomi Mi 4 Display Assembly Replacement
你所需要的
  1. Xiaomi Mi 4 Display Assembly Replacement, Rear Case/Midframe: 步骤 1 中的图像 1,3 Xiaomi Mi 4 Display Assembly Replacement, Rear Case/Midframe: 步骤 1 中的图像 2,3 Xiaomi Mi 4 Display Assembly Replacement, Rear Case/Midframe: 步骤 1 中的图像 3,3
    • Check to make sure that the device is powered off.
    • Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
    • Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
  2. Xiaomi Mi 4 Display Assembly Replacement: 步骤 2 中的图像 1,3 Xiaomi Mi 4 Display Assembly Replacement: 步骤 2 中的图像 2,3 Xiaomi Mi 4 Display Assembly Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Metal Spudger
    $2.99
    购买
    • Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
    • Using the second spudger, slowly work your way around the perimeter of the device
    • Listen for clicking sounds as you are prying the back cover away from the frame
    • As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
  3. Xiaomi Mi 4 Display Assembly Replacement: 步骤 3 中的图像 1,3 Xiaomi Mi 4 Display Assembly Replacement: 步骤 3 中的图像 2,3 Xiaomi Mi 4 Display Assembly Replacement: 步骤 3 中的图像 3,3
    • Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
    I don't think it is necessary to remove the three 0.5mm screws. Note: the right-most orange circle should be placed instead of the red circle above the two larger orange circles - those are the 0.5mm screws which secures a small plate under the plastic cover which is in NOT physically (but electrically via two metal contacts) to the mainboard.
    Douglas Ling - 回复
    yes, I expirienced the same thing. the three stated screws fixing a module (the flashlight LED-plate) on the frame..
    mobbom - 回复
  4. Xiaomi Mi 4 Display Assembly Replacement, Battery: 步骤 4 中的图像 1,3 Xiaomi Mi 4 Display Assembly Replacement, Battery: 步骤 4 中的图像 2,3 Xiaomi Mi 4 Display Assembly Replacement, Battery: 步骤 4 中的图像 3,3
    • Use tweezers to gently disconnect the connections that run across the battery and are connected to the motherboard.
    • Proceed to gently remove the tape like connector from the battery until it is completely off.
    • Use tweezer to disconnect battery’s wire from the motherboard.
    my mi4 had an accu Model “BM32” .. I ordered BM33 first. but the dimensions of the accu are different, so one can install only the right one.
    mobbom - 回复
  5. Xiaomi Mi 4 Display Assembly Replacement: 步骤 5 中的图像 1,2 Xiaomi Mi 4 Display Assembly Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to gently pry the battery out of its casing for removal.
    Using a Pry tool damaged a bit the casing of the battery. I ended up pulling the battery's plastic sticker to remove it (adhesive holding the battery in place)
    James Burton - 回复
    Is it safe, can we fix the back cover perfectly?
    Hemen Bhatt - 回复
  6. Xiaomi Mi 4 Display Assembly Replacement, Motherboard: 步骤 6 中的图像 1,1
    • With the battery removed locate the left-hand cable connected to the motherboard. With the tweezers, firmly grasp the wires of the connector and gently disconnect the cable from the motherboard.
    • Find the other cable connecting the motherboard to the device at the top right-hand side of the phone, and carefully use the tweezers to remove that as well.
    Where can i get the motherboard?
    Mohan Reddy - 回复
  7. Xiaomi Mi 4 Display Assembly Replacement: 步骤 7 中的图像 1,2 Xiaomi Mi 4 Display Assembly Replacement: 步骤 7 中的图像 2,2
    • Wedge the plastic opening tool, between the motherboard and the inner region of the phone in the slot atop the motherboard.
    Do not just try to pry open!
    Here you have to be careful, there are two plastic parts restraining the motherboard.
    - If we use the above picture as reference, there is the first plastic piece in the top right corner: push it out of the way.
    - Second piece of plastic: imagine the motherboard as a rectangle; the plastic piece is in the middle of the bottom segment.
    - Push it out, pry out.
    James Burton - 回复
    Also, in my phone, the mother board had a thin black cable connected to the down speaker.
    EDIT: You can disconnect the cable by using a prying tool to gently "unclip" the connector.
    James Burton - 回复
  8. Xiaomi Mi 4 Display Assembly Replacement, Display Assembly: 步骤 8 中的图像 1,2 Xiaomi Mi 4 Display Assembly Replacement, Display Assembly: 步骤 8 中的图像 2,2
    • After removing your device's back cover, battery, and motherboard, turn your phone over to start removing the LCD screen.
    • Start by fixing the suction cup firmly on the screen. Then wedge a plastic opening tool around the perimeter of the screen while maintaining a pulling force on the suction cup.
  9. Xiaomi Mi 4 Display Assembly Replacement: 步骤 9 中的图像 1,2 Xiaomi Mi 4 Display Assembly Replacement: 步骤 9 中的图像 2,2
    • Once you have pulled the screen completely off the device, there will be a ribbon wire that you previously detached from the motherboard that can be pulled gently through a hole.
    • Make sure you carefully dispose of the LCD screen if it is cracked in any way as to not be cut from the glass shards it may contain
结论
50等其他人完成本指南。
Robert Cobaich
于09/03/15注册
2,073 声望
创作了3篇指南
团队
USF Tampa, Team 16-1, Blackwell Winter 2016 USF Tampa, Team 16-1, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S16G1
4 名成员
创作了11篇指南
3条评论
This guide is completely useless. It skip passages like how to deal with the flash module, some ribbon cables to disconnect from the motherboard, the antenna, and most important of all, IT DOES NOT TELL YOU THAT YOU NEED A HEAT GUN FOR THE SCREEN REMOVAL. Terrible guide.
Tobia Apolloni - 回复
I've damaged some part of the silver coating( of the base plate) while trying to remove the existing screen module.Is that fine ?
Fittest Darwin - 回复
I agree with Tobia above, this guide is far too lacking in details to be really useful. If you need to replace the screen (or even simply the battery) of your xiaomi mi 4, you bettere refere to this video guide: https://www.youtube.com/watch?v=A693MYIg...
fmstasi - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 20
总计 23,609
