跳转到主内容
Xiaomi Mi 4 Battery Replacement
你所需要的
  1. Xiaomi Mi 4 Battery Replacement, Rear Case/Midframe: 步骤 1 中的图像 1,3 Xiaomi Mi 4 Battery Replacement, Rear Case/Midframe: 步骤 1 中的图像 2,3 Xiaomi Mi 4 Battery Replacement, Rear Case/Midframe: 步骤 1 中的图像 3,3
    • Check to make sure that the device is powered off.
    • Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
    • Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
  2. Xiaomi Mi 4 Battery Replacement: 步骤 2 中的图像 1,3 Xiaomi Mi 4 Battery Replacement: 步骤 2 中的图像 2,3 Xiaomi Mi 4 Battery Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Metal Spudger
    $2.99
    购买
    • Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
    • Using the second spudger, slowly work your way around the perimeter of the device
    • Listen for clicking sounds as you are prying the back cover away from the frame
    • As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
  3. Xiaomi Mi 4 Battery Replacement: 步骤 3 中的图像 1,3 Xiaomi Mi 4 Battery Replacement: 步骤 3 中的图像 2,3 Xiaomi Mi 4 Battery Replacement: 步骤 3 中的图像 3,3
    • Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
  4. Xiaomi Mi 4 Battery Replacement, Battery: 步骤 4 中的图像 1,3 Xiaomi Mi 4 Battery Replacement, Battery: 步骤 4 中的图像 2,3 Xiaomi Mi 4 Battery Replacement, Battery: 步骤 4 中的图像 3,3
    • Use tweezers to gently disconnect the connections that run across the battery and are connected to the motherboard.
    • Proceed to gently remove the tape like connector from the battery until it is completely off.
    • Use tweezer to disconnect battery’s wire from the motherboard.
  5. Xiaomi Mi 4 Battery Replacement: 步骤 5 中的图像 1,2 Xiaomi Mi 4 Battery Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to gently pry the battery out of its casing for removal.
结论
48等其他人完成本指南。
团队
USF Tampa, Team 15-6, Blackwell Fall 2015 USF Tampa, Team 15-6, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S15G6
2 名成员
创作了10篇指南
24条评论
Sir, I accidentally put a hole in battery while removing. Will this create a problem/explosion..
Apawilo Zawk - 回复
Hey Apawilo. A punctured battery has potential to be very dangerous (Fire, harmful chemicals, etc), so please make sure to dispose of it at the nearest e-waste recycling site.
Geoff Wacker -
sir i am charging my phone but its percentage is not increasing ....this is a battery problem
adishsaggar123 - 回复
im having the similar problem, when charging power increase slower and the consumption is faster than usual. please advice. thanks
Zeff Soo -
Hi..my xiaomi 4 cant be started.. after fully charged, it went blank n cant be restarted.. few days back, it was on n of for multiple time for several minutes...
Ezrat sam - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 86
总计 147,246
