跳转到主内容
Xiaomi Air 12 Speaker Replacement
你所需要的
  1. Xiaomi Air 12 Speaker Replacement, Rear Casing: 步骤 1 中的图像 1,1
    • Orient the computer so the Xiaomi logo is at the bottom of the device.
  2. Xiaomi Air 12 Speaker Replacement: 步骤 2 中的图像 1,3 Xiaomi Air 12 Speaker Replacement: 步骤 2 中的图像 2,3 Xiaomi Air 12 Speaker Replacement: 步骤 2 中的图像 3,3
    • Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
  3. Xiaomi Air 12 Speaker Replacement: 步骤 3 中的图像 1,2 Xiaomi Air 12 Speaker Replacement: 步骤 3 中的图像 2,2
    • Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
  4. Xiaomi Air 12 Speaker Replacement: 步骤 4 中的图像 1,3 Xiaomi Air 12 Speaker Replacement: 步骤 4 中的图像 2,3 Xiaomi Air 12 Speaker Replacement: 步骤 4 中的图像 3,3
    • Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
    • You will hear popping noises as you remove the cover.
  5. Xiaomi Air 12 Speaker Replacement: 步骤 5 中的图像 1,2 Xiaomi Air 12 Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove the back of the laptop by gently lifting the casing upwards.
  6. Xiaomi Air 12 Speaker Replacement, Speaker: 步骤 6 中的图像 1,2 Xiaomi Air 12 Speaker Replacement, Speaker: 步骤 6 中的图像 2,2
    • Remove the white and black speaker wires from the black tabs by pulling upwards from the device.
  7. Xiaomi Air 12 Speaker Replacement: 步骤 7 中的图像 1,2 Xiaomi Air 12 Speaker Replacement: 步骤 7 中的图像 2,2
    • Gently pull the speaker connector out from the connection point using your hand.
  8. Xiaomi Air 12 Speaker Replacement: 步骤 8 中的图像 1,3 Xiaomi Air 12 Speaker Replacement: 步骤 8 中的图像 2,3 Xiaomi Air 12 Speaker Replacement: 步骤 8 中的图像 3,3
    • Remove the left speaker module by pulling the panel up from the device.
    • Repeat the same process for the right speaker module.
    • Left and Right speaker modules are denoted by an "L" and "R" respectively.
    • There will be a slight adhesive underneath the module.
结论
2等其他人完成本指南。
Hannah Kwan
于04/18/18注册
824 声望
创作了5篇指南
团队
Cal Poly, Team S18-G4, Livingston Spring 2018 Cal Poly, Team S18-G4, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S18G4
4 名成员
创作了20篇指南
6条评论
Thanks for the tutorial! But where can i buy replacement speakers? My right speaker is overdriving all the time now, giving me a lot of loud buzz noises.
Nicolai - 回复
The same for me. I’d like to replace the speakers because one of them is “crackling/vibrating”, but i don’t know where to buy them…
Maniac 45 - 回复
same problem, mine at >50% vibrating very bad
isman87 - 回复
have you found them? i need those too
Giorgio Pianesi -
Hello, i love this laptop and its been my companion for almost 3 years think the audio input jack got grounded because i heard a creaking sound when i inserted a metallic headset jack, the device was charging when it happened. Now the audio output from the audio jack port is like a minus one or somewhat instrumental. Any suggestions what to do?
James Prae Liclican - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 1,017
