跳转到主内容
Xelio P900A-BK Screen Replacement
你所需要的
  1. Xelio P900A-BK Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Remove the two bottom screws.
    • The two bottom screws have a 2.44mm wide tops and are 5.44mm.
  2. Xelio P900A-BK Screen Replacement: 步骤 2 中的图像 1,2 Xelio P900A-BK Screen Replacement: 步骤 2 中的图像 2,2
    • Slide the spludger between the screen's rolled edge and the back of the tablet and pry apart carefully. Expect the tablet screen to make a cracking sound.
    • Slide the spudger in the slit all the way around the perimeter of the tablet to fully separate the screen.
  3. Xelio P900A-BK Screen Replacement: 步骤 3 中的图像 1,1
    • Once the screen has fully separated from the back of the tablet, gently lift up the edges to remove the screen.
  4. Xelio P900A-BK Screen Replacement: 步骤 4 中的图像 1,2 Xelio P900A-BK Screen Replacement: 步骤 4 中的图像 2,2
    • Next, disconnect the front facing camera ribbon (shown). The ribbon is held to the motherboard by a small bar.
    • Using the spudger to pry open the bar, pull the ribbon out to disconnect it.
  5. Xelio P900A-BK Screen Replacement: 步骤 5 中的图像 1,2 Xelio P900A-BK Screen Replacement: 步骤 5 中的图像 2,2
    • Next, work on disconnecting the ribbon for the touch screen.
    • The touch screen ribbon is larger than the camera ribbon and is located on the left side of motherboard.
    • Using the spudger, gently pry the ribbon out from under the bar. Pull the ribbon and disconnect it from the motherboard.
  6. Xelio P900A-BK Screen Replacement: 步骤 6 中的图像 1,3 Xelio P900A-BK Screen Replacement: 步骤 6 中的图像 2,3 Xelio P900A-BK Screen Replacement: 步骤 6 中的图像 3,3
    • Next, work to disconnect the LCD screen ribbon.
    • This ribbon is located on the right side of the motherboard.
    • The ribbon is connected to the motherboard by a small bar. Using the spudger, pry the bar apart and slide the ribbon out.
  7. Xelio P900A-BK Screen Replacement: 步骤 7 中的图像 1,3 Xelio P900A-BK Screen Replacement: 步骤 7 中的图像 2,3 Xelio P900A-BK Screen Replacement: 步骤 7 中的图像 3,3
    • Remove the two motherboard screws.
    • To remove the first screw, expose the black strip. Then using a Philips head screwdriver, remove the first screw.
    • Locate the second screw by looking to the bottom right of the motherboard. Remove the second screw with the Philips head screwdriver.
  8. Xelio P900A-BK Screen Replacement: 步骤 8 中的图像 1,2 Xelio P900A-BK Screen Replacement: 步骤 8 中的图像 2,2
    • Locate the last connection to the LCD in the top right section of the tablet.
    • The last connection is a ribbon connected to green wire, which is held down by tape.
    • Disconnect the ribbon by removing the tape connecting it to the plastic frame of the tablet.
  9. Xelio P900A-BK Screen Replacement: 步骤 9 中的图像 1,1
    • With the spudger, pry the LCD screen from the plastic screen holder.
    • Use gentle, but firm force to pry the LCD away from the holder.
  10. Xelio P900A-BK Screen Replacement: 步骤 10 中的图像 1,1
    • Work the spudger all the way around until the LCD is free from the screen holder.
  11. Xelio P900A-BK Screen Replacement: 步骤 11 中的图像 1,1
    • Finally, lift the LCD off, removing it from the screen holder and the motherboard.
结论
另外一个人完成了本指南。
Marcus Nelson
于03/26/15注册
307 声望
创作了3篇指南
团队
UMass Dartmouth, Team 7-6, Cichon Spring 2015 UMass Dartmouth, Team 7-6, Cichon Spring 2015 的会员
UMASSD-CICHON-S15S7G6
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 380
