跳转到主内容
Xelio P1001A-BK Wi-Fi Antenna Replacement
你所需要的
  1. Xelio P1001A-BK Wi-Fi Antenna Replacement, Back Cover: 步骤 1 中的图像 1,2 Xelio P1001A-BK Wi-Fi Antenna Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the two 3 mm retaining screws from the side of the tablet with a Phillips #0 screwdriver.
  2. Xelio P1001A-BK Wi-Fi Antenna Replacement: 步骤 2 中的图像 1,2 Xelio P1001A-BK Wi-Fi Antenna Replacement: 步骤 2 中的图像 2,2
    • Insert the plastic opening tool in between the shelf halves and lift the top shelf half to detach the securing tabs.
    • There are four securing tabs located on each long side.
    • Before fully separating the shell halves, observe if the speakers are separated from the shell half. If they are still in their sockets, gently pry them loose with the plastic opening tool.
  3. Xelio P1001A-BK Wi-Fi Antenna Replacement, Wi-Fi Antenna: 步骤 3 中的图像 1,2 Xelio P1001A-BK Wi-Fi Antenna Replacement, Wi-Fi Antenna: 步骤 3 中的图像 2,2
    • Desolder the connection on the motherboard.
    • Use a soldering vacuum to remove any excess solder.
  4. Xelio P1001A-BK Wi-Fi Antenna Replacement: 步骤 4 中的图像 1,1
    • Use wire strippers to strip off at least 2 mm of wire insulation from each wire.
  5. Xelio P1001A-BK Wi-Fi Antenna Replacement: 步骤 5 中的图像 1,1
    • Solder the outer wire braid shield to the ground point.
  6. Xelio P1001A-BK Wi-Fi Antenna Replacement: 步骤 6 中的图像 1,1
    • Solder the center conductor to the antenna point.
结论
Josh Saenz
于03/11/15注册
316 声望
创作了3篇指南
团队
Colorado Springs, Team 4-2, Panko Spring 2015 Colorado Springs, Team 4-2, Panko Spring 2015 的会员
UCCS-PANKO-S15S4G2
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 154
