跳转到主内容
Xelio P1001A-BK Speakers Replacement
你所需要的
  1. Xelio P1001A-BK Speakers Replacement, Back Cover: 步骤 1 中的图像 1,2 Xelio P1001A-BK Speakers Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the two 3 mm retaining screws from the side of the tablet with a Phillips #0 screwdriver.
  2. Xelio P1001A-BK Speakers Replacement: 步骤 2 中的图像 1,2 Xelio P1001A-BK Speakers Replacement: 步骤 2 中的图像 2,2
    • Insert the plastic opening tool in between the shelf halves and lift the top shelf half to detach the securing tabs.
    • There are four securing tabs located on each long side.
    • Before fully separating the shell halves, observe if the speakers are separated from the shell half. If they are still in their sockets, gently pry them loose with the plastic opening tool.
  3. Xelio P1001A-BK Speakers Replacement, Speakers: 步骤 3 中的图像 1,2 Xelio P1001A-BK Speakers Replacement, Speakers: 步骤 3 中的图像 2,2
    • Desolder the two speaker wires with the soldering iron by melting the solder so the wires can be removed.
    • Remove the wires from the soldering points once they have loosened.
    • Use a soldering vacuum to remove the excess solder from the board.
  4. Xelio P1001A-BK Speakers Replacement: 步骤 4 中的图像 1,1
    • Inspect your wires. You should see 2 mm of exposed wire before you move to the next step.
    • If necessary, use your wire-stripping tool to strip 2 mm of insulation from each wire.
  5. Xelio P1001A-BK Speakers Replacement: 步骤 5 中的图像 1,1
    • Place the exposed wire in the soldering point.
    • Apply the soldering iron to the point just until the wire is secured.
    • Repeat these two steps for the second wire.
结论
Josh Saenz
于03/11/15注册
316 声望
创作了3篇指南
团队
Colorado Springs, Team 4-2, Panko Spring 2015 Colorado Springs, Team 4-2, Panko Spring 2015 的会员
UCCS-PANKO-S15S4G2
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 160
