跳转到主内容
Xelio P1001A-BK Rear Camera Replacement
你所需要的
  1. Xelio P1001A-BK Rear Camera Replacement, Back Cover: 步骤 1 中的图像 1,2 Xelio P1001A-BK Rear Camera Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the two 3 mm retaining screws from the side of the tablet with a Phillips #0 screwdriver.
  2. Xelio P1001A-BK Rear Camera Replacement: 步骤 2 中的图像 1,2 Xelio P1001A-BK Rear Camera Replacement: 步骤 2 中的图像 2,2
    • Insert the plastic opening tool in between the shelf halves and lift the top shelf half to detach the securing tabs.
    • There are four securing tabs located on each long side.
    • Before fully separating the shell halves, observe if the speakers are separated from the shell half. If they are still in their sockets, gently pry them loose with the plastic opening tool.
  3. Xelio P1001A-BK Rear Camera Replacement, Rear Camera: 步骤 3 中的图像 1,1
    • Locate ribbon connector, make sure it is secure.
  4. Xelio P1001A-BK Rear Camera Replacement: 步骤 4 中的图像 1,1
    • With a plastic opening tool, gently pry the camera body from its retaining socket
  5. Xelio P1001A-BK Rear Camera Replacement: 步骤 5 中的图像 1,1
    • Make sure the camera is unobstructed
  6. Xelio P1001A-BK Rear Camera Replacement: 步骤 6 中的图像 1,3 Xelio P1001A-BK Rear Camera Replacement: 步骤 6 中的图像 2,3 Xelio P1001A-BK Rear Camera Replacement: 步骤 6 中的图像 3,3
    • If there is still no picture, remove the securing tab on the ribbon connector by inserting the plastic opening tool between the tab on the ribbon cable connector body.
    • Slowly twist the opening tool to loosen the tab. Move the screwdriver to different parts of the tab to move it a little bit at a time.
    • Once the tab is loose, remove it then slide the ribbon cable from its connector and remove the camera from the tablet
  7. Xelio P1001A-BK Rear Camera Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    购买
    • With a microfiber lens cleaning cloth, clean the camera lens
  8. Xelio P1001A-BK Rear Camera Replacement: 步骤 8 中的图像 1,3 Xelio P1001A-BK Rear Camera Replacement: 步骤 8 中的图像 2,3 Xelio P1001A-BK Rear Camera Replacement: 步骤 8 中的图像 3,3
    • To install a new camera, slide the ribbon cable back into its connector
    • Reinstall the ribbon cable securing tab
    • Note the indentation that goes along the edge of the securing tab. It must be facing up to orient the tab correctly
    • Install the camera in its retaining socket
结论
Caleb
于03/11/15注册
101 声望
撰写一个指南
团队
Colorado Springs, Team 4-2, Panko Spring 2015 Colorado Springs, Team 4-2, Panko Spring 2015 的会员
UCCS-PANKO-S15S4G2
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 120
