跳转到主内容
Xelio P1001A-BK Battery Pack Replacement
你所需要的
  1. Xelio P1001A-BK Battery Pack Replacement, Back Cover: 步骤 1 中的图像 1,2 Xelio P1001A-BK Battery Pack Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the two 3 mm retaining screws from the side of the tablet with a Phillips #0 screwdriver.
  2. Xelio P1001A-BK Battery Pack Replacement: 步骤 2 中的图像 1,2 Xelio P1001A-BK Battery Pack Replacement: 步骤 2 中的图像 2,2
    • Insert the plastic opening tool in between the shelf halves and lift the top shelf half to detach the securing tabs.
    • There are four securing tabs located on each long side.
    • Before fully separating the shell halves, observe if the speakers are separated from the shell half. If they are still in their sockets, gently pry them loose with the plastic opening tool.
  3. Xelio P1001A-BK Battery Pack Replacement, Battery Pack: 步骤 3 中的图像 1,2 Xelio P1001A-BK Battery Pack Replacement, Battery Pack: 步骤 3 中的图像 2,2
    • De-solder the two wires that connect the battery pack to the motherboard using a needle-nose plier and a soldering iron.
    • Wrap the exposed end of the black negative wire with electrical tape.
  4. Xelio P1001A-BK Battery Pack Replacement: 步骤 4 中的图像 1,1
    • Trace the outline of the battery pack on the screen back shield with a black Sharpie marker.
    • This will aid in positioning the new battery pack.
  5. Xelio P1001A-BK Battery Pack Replacement: 步骤 5 中的图像 1,1
    • WARNING: Never use a knife or sharp object around a battery. Puncturing a battery may potentially cause a fire.
    • Carefully slide a spudger under the adhesive pads in between the battery pack and the screen back shield.
    • Remove the battery pack.
    • Avoid bending the battery pack.
  6. Xelio P1001A-BK Battery Pack Replacement: 步骤 6 中的图像 1,1
    • Apply a small amount of silicon glue to the new battery on the side it will touch the screen back shield.
    • Place the battery pack on the screen back shield inside the outline.
  7. Xelio P1001A-BK Battery Pack Replacement: 步骤 7 中的图像 1,2 Xelio P1001A-BK Battery Pack Replacement: 步骤 7 中的图像 2,2
    • Solder the red battery wire to the point labeled BATT +, and the black battery wire to the point BATT -.
    • If the wire ends are not exposed, strip 3mm of insulation from the end using a wire stripper. Start with the black negative wire and wrap the exposed ends with electrical tape.
结论
Michael Case
于03/11/15注册
110 声望
创作了2篇指南
团队
Colorado Springs, Team 4-2, Panko Spring 2015 Colorado Springs, Team 4-2, Panko Spring 2015 的会员
UCCS-PANKO-S15S4G2
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 197
