跳转到主内容
Xbox Series S Power Button Board Replacement
你所需要的
  1. Xbox Series S Power Button Board Replacement, Peel off the sticker coverings: 步骤 1 中的图像 1,3 Xbox Series S Power Button Board Replacement, Peel off the sticker coverings: 步骤 1 中的图像 2,3 Xbox Series S Power Button Board Replacement, Peel off the sticker coverings: 步骤 1 中的图像 3,3
    • Before you start this guide, turn off the Xbox and unplug any cables from it.
    • Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
    • Use a T8 Torx driver to remove the two 10 mm-long screws securing the back panel to the bottom panel.
  2. Xbox Series S Power Button Board Replacement, Remove the bottom panel: 步骤 3 中的图像 1,3 Xbox Series S Power Button Board Replacement, Remove the bottom panel: 步骤 3 中的图像 2,3 Xbox Series S Power Button Board Replacement, Remove the bottom panel: 步骤 3 中的图像 3,3
    • Slide the bottom panel horizontally toward the back of the console until it comes to a stop.
    • This slides the clips out of the slots on the plastic case.
    • Lift straight up and remove the bottom panel from the plastic case.
  3. Xbox Series S Power Button Board Replacement, Remove the plastic case screws: 步骤 4 中的图像 1,1
    • Use a T10 Torx driver to remove the seven 51 mm-long screws securing the chassis to the plastic case.
  4. Xbox Series S Power Button Board Replacement, Remove the plastic case: 步骤 5 中的图像 1,3 Xbox Series S Power Button Board Replacement, Remove the plastic case: 步骤 5 中的图像 2,3 Xbox Series S Power Button Board Replacement, Remove the plastic case: 步骤 5 中的图像 3,3
    • With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other.
    • As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from the plastic case.
    • The back panel should now settle on top of the clips on the back of the plastic case.
    • The back panel is permanently attached to the aluminum chassis.
    • Do not attempt to fully remove the chassis from the plastic case with this technique. You may risk breaking your case.
  5. Xbox Series S Power Button Board Replacement: 步骤 6 中的图像 1,3 Xbox Series S Power Button Board Replacement: 步骤 6 中的图像 2,3 Xbox Series S Power Button Board Replacement: 步骤 6 中的图像 3,3
    • Pull the bottom-left corner away from the chassis while swinging the chassis away from the plastic case.
    • You may need to lift the chassis to free it from the clips on the bottom-front of the plastic case during this process.
    • Remove the plastic case from the chassis.
  6. Xbox Series S Power Button Board Replacement, Remove the power button board: 步骤 7 中的图像 1,1
    • Use a T8 Torx driver to remove the 9.5 mm-long screw securing the power button board to the chassis.
  7. Xbox Series S Power Button Board Replacement: 步骤 8 中的图像 1,3 Xbox Series S Power Button Board Replacement: 步骤 8 中的图像 2,3 Xbox Series S Power Button Board Replacement: 步骤 8 中的图像 3,3
    • Use a spudger to pry and loosen the power button board.
    • Do not pry from the bottom of the power button board as it may bend the connector.
    • Pull the power button board straight out to disconnect it from the chassis.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Robert Boyd
于02/01/21注册
24,183 声望
创作了94篇指南
一条评论
Can you tell me what on the power button board turns the console on?
Dreshaun Norman - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 33
过去 30 天: 168
总计 2,403
