简介
This is the guide to replacing the unit that deals with power in the Microsoft Xbox. This is potentially the cause of the Xbox not turning on.
你所需要的
Remove the disk drive. It should come right out.
Unplug the ribbon cable and yellow cables from back of disk drive.
Unplug the multi-colored power cord from the motherboard. It is in there pretty tightly, so it may take some effort.
35等其他人完成本指南。
2指南评论
http://www.ebay.com/gds/How-To-Determine...
Utilize the information on this website to determine what Xbox version you have so you know what replacement parts to look for.
you say to lift out power supply without touching coil or capacitor and set aside. what is it safe to set it onto? i imagine there is also risk of arc if set on the wrong surface. is glass safe? how do you check for live voltage before handling those components?
