跳转到主内容
Xbox One X Project Scorpio Edition Outer Case Replacement
你所需要的
  1. Xbox One X Project Scorpio Edition Outer Case Replacement, Outer Case: 步骤 1 中的图像 1,2 Xbox One X Project Scorpio Edition Outer Case Replacement, Outer Case: 步骤 1 中的图像 2,2
    • Use a T9 Torx screwdriver to remove the 13mm screw which is under and to the left of the power input.
  2. Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 2 中的图像 1,3 Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 2 中的图像 2,3 Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 2 中的图像 3,3
    • Using precision tweezers, remove the screw tab located on opposite side of the box.
    • Use a T9 Torx screwdriver to remove the 13mm screw revealed underneath the tab.
  3. Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 3 中的图像 1,3 Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 3 中的图像 2,3 Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 3 中的图像 3,3
    • Orient the case so that the front of the Xbox (the side with the power button) is facing you.
    • Remove the top of the case by sliding the case towards you.
  4. Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 4 中的图像 1,3 Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 4 中的图像 2,3 Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 4 中的图像 3,3
    • Using a T9 Torx screwdriver, remove the two 15mm silver screws that are holding a circuit board/panel to the side of the interior metal casing.
    • Using the same screwdriver, remove the 9mm black screw located farther to the right on the same circuit board/panel.
  5. Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 5 中的图像 1,2 Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 5 中的图像 2,2
    • Remove the unscrewed panel from the side of the device by pulling it toward you.
    • Be mindful of the connector, as it is fragile.
  6. Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 6 中的图像 1,2 Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 6 中的图像 2,2
    • Pull the upper edge of the white clip down, and then remove the white connector from the dislocated panel using precision tweezers.
    • Do not force the connector out, as it is fragile. Wiggling may be necessary.
  7. Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 7 中的图像 1,3 Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 7 中的图像 2,3 Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 7 中的图像 3,3
    • On the top of the device in the corner directly above the white connector, there is an oval plate held in place by two screws.
    • Remove both of these 7mm screws with a Torx T9 screwdriver.
    • Lift the detached plate off to the side.
    • The plate is still connected to the device.
  8. Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 8 中的图像 1,2 Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 8 中的图像 2,2
    • Use a Torx T9 screwdriver to remove the six 47mm long screws, which attach the bottom side of the outer case.
  9. Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 9 中的图像 1,3 Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 9 中的图像 2,3 Xbox One X Project Scorpio Edition Outer Case Replacement: 步骤 9 中的图像 3,3
    • Turn the Xbox over, so that the bottom of the case is on top.
    • Lift the bottom of the case off of the Xbox by pulling it up and toward you.
结论
7等其他人完成本指南。
Ashley Masuda
于01/24/18注册
2,763 声望
创作了7篇指南
团队
Cal Poly, Team S2-G6, Livingston Winter 2018 Cal Poly, Team S2-G6, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S2G6
4 名成员
创作了23篇指南
2条评论
Where do you get the outer case from? And if I only want to replace the outer case could I just follow the first 3 steps?
Daniel - 回复
Following. I need a replacement project Scorpio case. the system I got it from was from Mercari and the guy did a poor job in taking care of the case and I need a top Scorpio case.
Britteny X. Wilson -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 5,299
