跳转到主内容
Xbox One 无线控制器 顶部主板更换
你所需要的
  1. Xbox One 无线控制器 顶部主板更换, 电池: 步骤 1 中的图像 1,1
    • 移除电池盖
    • 拆下电池
  2. Xbox One 无线控制器 顶部主板更换, 侧背板: 步骤 2 中的图像 1,2 Xbox One 无线控制器 顶部主板更换, 侧背板: 步骤 2 中的图像 2,2
    • 我们建议使用尼龙撬棒完成以下工作,图示为金属撬棒
    • 紧握手柄,将撬棒插入前后面板的缝隙中
    • 使用撬棒小心的撬开边上的卡扣,然后拆除后面的塑料侧背板
    Start prying the side plate off underneath the trigger, this makes it easier to disconnect the other clips connecting the side plate to the backplate.
    Brandon - 回复
    One you take it off, is it possible to click it back in?
    Aiden Bear - 回复
    As long as you don’t exceed the couple tons you need to take it off you should be able to put it back.
    Brandon -
    I don’t have a squdger
    TimidFerret4982 Gaming - 回复
    getting those handles back on seems impossible, they just dont fit as well, a gap remains even after snapping into place.
    Dont think ill be doing this in the future
    Spoutin Wyze - 回复
    edit: wiggled the bo9ttom middlewith the handles off and somethign finally “clicked” into place for that extra 1/4 mm for the down arrow on my D-Pad to click back up into place!.
    Spoutin Wyze - 回复
  3. Xbox One 无线控制器 顶部主板更换, 螺丝: 步骤 3 中的图像 1,2 Xbox One 无线控制器 顶部主板更换, 螺丝: 步骤 3 中的图像 2,2
    • 在标签下有一个隐藏的螺丝
    • 用螺丝刀穿透标签,卸下这颗螺丝
    • 如果不想穿透标签的话,你也可以将标签撕下来
    • 使用T8梅花螺丝刀把剩余的五个用于固定手柄后盖的 10 mm 螺丝拆卸下来。
    i damaged my screws. how do i get the screws out?
    tenzin - 回复
    wait. i just watched a video guide on ifixit's youtube channel about damaged screws. i'll try those methods.
    tenzin - 回复
    It's a t8 or t9 security bit btw, I got the top two out with a regular T8, but the bottom two and middle needed a T9 Security bit.
    David Loper - 回复
    All five faceplate/backplate screws in the controller I disassembled were T8 security fasteners.
    John Dziedzic - 回复
    Am I doing something wrong because I got the tool it said I needed and got the middle screw out but the others have a bump or something in the center of the screw and it won't fit.
    kolton77 - 回复
    The T8 is only good for the middle screw on my One S controller. The others require something bigger
    Matej Skelo - 回复
    These requires SECURITY Torx bits (they have a cannulated hole in the driver). I don't believe the iFixIt branded driver is cannulated but you can buy a set of bits from DeWalt DWAX200 which is overkill but has what you need.
    jhighsmith - 回复
    The driver that iFixIt sells is cannulated.
    jhighsmith -
    where do you get this dumb ass screw driver
    Jake Zweier - 回复
    iFixit Store #IF145-027-3
    VauWeh - 回复
    You can bypass it with a 1.5mm flathead.
    Marianne Sandling - 回复
    thank you for this. worked for me
    Mr Anderson (Evolluisionist) -
    These screws required a T10, not T8.
    Armand - 回复
    TR9. A $10 kit from Walmart has the bit/driver in it and extra goodies to make life simple.
    Matt Martin - 回复
    As weird as it sounds, the top 2 came out for me with a flathead- but the bottom two and the middle one wont
    macybrooksevans - 回复
    If you damage the middle part of the screws you can still take it out with the same screwdriver.
    Kev God - 回复
    Thank-You :)
    Isaiah - 回复
    needed a T8H, not easy to see.
    on a grey green xbox one controller
    Michael - 回复
    On my 1708 controller there are two internal screws near the rumble motors that need to be removed with a T6 non security bit to remove the back cover.
    teeedubb - 回复
  4. Xbox One 无线控制器 顶部主板更换, 背板: 步骤 4 中的图像 1,1
    • 把背板拿下来
  5. Xbox One 无线控制器 顶部主板更换, 前面板: 步骤 5 中的图像 1,1
    • 把前面板拿下来
  6. Xbox One 无线控制器 顶部主板更换, 顶部主板: 步骤 6 中的图像 1,2 Xbox One 无线控制器 顶部主板更换, 顶部主板: 步骤 6 中的图像 2,2
    • 你可以让振动马达从插座中松开。
    • 脱焊 焊接接头,同时将红色和黑色电线按在顶部主板上。
    • 脱焊 焊接在顶部主板上的黑色和灰色线。
    • 拆下振动马达并将其放在一边。
    • 使用烙铁时要小心,不要损坏其他部件或伤害自己。
    • 有关如何焊接的信息,请点击此处
    Steps 6-8 aren't completely necessary, and are very risky if you aren't good at soldering. It would seem the only reason to remove the motherboard and mess with all this soldering is just so you can reach both screws on the trigger in step 10. However, you can reach them already with a small-bodied screwdriver. Although you might have to rest the screwdriver on the black square processor to reach the bottom screw, it shouldn't damage the processor or motherboard to jimmy that screw out.
    Robert Rapier - 回复
    like mentioned by ‘Robert Rapier’ you can skip the de-soldering in most cases,
    for example cleaning or changing the buttons is doable, but the grey and black wires are pretty short
    and wired through the inner case so it can get a bit fiddly and you have to be careful not to damage them in the process.
    If you have a soldering station around i would still recommend using it.
    yKekS Yzz - 回复
    Thanks to above commenters. Can confirm I was able to do a button repair without soldering. Thank you all!
    Matt Hunt - 回复
    If you peal back the Kapton tape mounting the grey/black wires there is enough play to maneuver all the boards for cleaning most of the buttons from a soda spill. Cleaning the dimple buttons on the mother board by immersion requires the de-solder...
    agzero - 回复
  7. Xbox One 无线控制器 顶部主板更换: 步骤 7 中的图像 1,1
    • 移除振动马达插座附近的两颗7mm T6螺丝。
    Are these just T6 screws or Torx security T6 that is cannulated?
    Kenan Vickstrom - 回复
    The outer screws are security screws. The ones on the system boards are Torx.
    Rongwey -
  8. Xbox One 无线控制器 顶部主板更换: 步骤 8 中的图像 1,1
    • 牢牢抓住主板靠近中间的两侧。
    • 向上抬起,同时向前和向后稍微摆动主板。
    • 抬起主板将需要一些力量。
    Hola, como se instala el software a la nueva placa base ?
    MANSONN755 - 回复
结论
要重新组装您的设备,请按照本指南的相反顺序进行操作。
28等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Liam Gow
于01/22/15注册
5,285 声望
创作了3篇指南
团队
Cal Poly, Team 20-15, Maness Winter 2015 Cal Poly, Team 20-15, Maness Winter 2015 的会员
CPSU-MANESS-W15S20G15
5 名成员
创作了50篇指南
6条评论
where can i get a top motherborde replacement??
Lol John - 回复
Hi John,
Unfortunately, beyond the parts list given on the main page, I don't know of any other reliable links. I'd suggest Googling the part, or maybe searching on eBay.
Liam Gow -
I was only able to unscrew 2 of the Torx screws. They have a pin right in the middle that doesn't allow for the screwdriver to be fully inserted, or at all. The two screws I was able to unscrew must've had a shorter pin than the others.
Rami Girgis - 回复
These points on the head is what we call a security torx screw. You will need the specific T8 or T6 Security Torx Screwdriver to remove these screws.
jbagge0023 -
You can use a small flat blade screwdriver ;-)
If any of the screws are tight, the centre pin may snap, then you can just use a normal Torx bit.
Lee Houston -
Salut, merci pour le tuto bien expliqué. Je sais déjà démonter, remonter entièrement ma manette, sais-tu ou acheter des carte-mere pour manette xhox one ? Celle qui tient les deux joysticks. Bonne journée
PoolpoHz - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 49
过去 30 天: 259
总计 75,691
