跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Xbox One Wireless Controller Model 1537,请使用我们的维修手册
  1. Xbox One Wireless Controller Teardown, Get an Xbox One Controller: 步骤 1 中的图像 1,1
    • Start off with having an Xbox One Controller (:
  2. Xbox One Wireless Controller Teardown, Remove First Screw: 步骤 2 中的图像 1,2 Xbox One Wireless Controller Teardown, Remove First Screw: 步骤 2 中的图像 2,2
    • Start with removing the battery pack and exposing the T8 security screw. The screw should be hidden behind a warranty sticker.
  3. Xbox One Wireless Controller Teardown, Remove side panels: 步骤 3 中的图像 1,3 Xbox One Wireless Controller Teardown, Remove side panels: 步骤 3 中的图像 2,3 Xbox One Wireless Controller Teardown, Remove side panels: 步骤 3 中的图像 3,3
    • Remove the side panels exposing the second T8 security screw using a spudger, an IFixit Opening Tool, or your nails, each choice is fun.
  4. Xbox One Wireless Controller Teardown, Remove all screws: 步骤 4 中的图像 1,1
    • By removing all side panels all 5 T8 security screws have appeared!
  5. Xbox One Wireless Controller Teardown, Remove Faceplate: 步骤 5 中的图像 1,3 Xbox One Wireless Controller Teardown, Remove Faceplate: 步骤 5 中的图像 2,3 Xbox One Wireless Controller Teardown, Remove Faceplate: 步骤 5 中的图像 3,3
    • Once you removed the T8 security screws remove the front face plate.
  6. Xbox One Wireless Controller Teardown, Tape down rumble motors: 步骤 6 中的图像 1,2 Xbox One Wireless Controller Teardown, Tape down rumble motors: 步骤 6 中的图像 2,2
    • Tape down the rumbler motors to prevent them from falling out.
  7. Xbox One Wireless Controller Teardown, Remove T6 screws: 步骤 7 中的图像 1,3 Xbox One Wireless Controller Teardown, Remove T6 screws: 步骤 7 中的图像 2,3 Xbox One Wireless Controller Teardown, Remove T6 screws: 步骤 7 中的图像 3,3
    • Remove the T6 screws to remove the PCB's.
    • It takes a pull to seperate the connectors.
    • Watch the wires! You can not fully remove the circuit board without removing the wires and it requires soldering.
  8. Xbox One Wireless Controller Teardown: 步骤 8 中的图像 1,3 Xbox One Wireless Controller Teardown: 步骤 8 中的图像 2,3 Xbox One Wireless Controller Teardown: 步骤 8 中的图像 3,3
    • Remove the top cover, it folds over.
    • There are 6 T6 screws to remove.
  9. Xbox One Wireless Controller Teardown: 步骤 9 中的图像 1,3 Xbox One Wireless Controller Teardown: 步骤 9 中的图像 2,3 Xbox One Wireless Controller Teardown: 步骤 9 中的图像 3,3
    • Remove the circuit board
    • Under the rubber is the A B X Y buttons.
  10. Xbox One Wireless Controller Teardown: 步骤 10 中的图像 1,3 Xbox One Wireless Controller Teardown: 步骤 10 中的图像 2,3 Xbox One Wireless Controller Teardown: 步骤 10 中的图像 3,3
    • Follow the instructions in reverse to get everything together again. :D
ubaldo gutierrez
于11/07/16注册
262 声望
撰写一个指南
15条评论
Very good instructions...
Chadwick Posey - 回复
Nice instructions. I need to take apart mine and replace the d-pad. The previous owner was a bit... rough. Sometimes it doesn't work or it clicks twice. Cheers!
Johnathan - 回复
Do you think that you can label the internals of the controller.
David Becerra - 回复
I have a custom controller from the xbox design labs. I want to change the led on the front.
Can someone point out the model/ size led I would need?
Alajandro - 回复
How do you put the sync buttom back in? Which way does it face?
Throaty Sea5 - 回复
添加评论
浏览统计数据:
过去 24 小时: 29
过去 7 天: 258
过去 30 天: 1,395
总计 168,382
