跳转到主内容
修复你的物品
维修的权力
商店
简介
The Joysticks on your Xbox Controller could become unresponsive or sticky. If this happens it could be necessary to remove the Joysticks to either replace or clean them. This guide will teach you how to access and replace the Joysticks on your Xbox One Wireless Controller Model 1708.
  1. Slide the battery cover toward the top of the controller to remove it. Lift up  the batteries or the battery pack from the battery compartment.
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
  2. Insert a plastic opening tool into the top seam, and  gently work the opening tool to the bottom of the controller. Continue using the opening tool to gently pry the side plate off of the controller.
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
  3. Gently peel the battery label  or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
  4. Orient the controller so the front plate is facing up. Lift the front cover off of the controller.
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
  5. Turn the controller face down and gently lift the rear plate.
    • Turn the controller face down and gently lift the rear plate.
  6. Pull the joysticks off of the controller.
    • Pull the joysticks off of the controller.
结论
90等其他人完成本指南。
Dylan Gross
于2017年09月25日注册
3,650 信誉积分
创作了4篇指南
团队
Cal Poly, Team S18-G3, Forte Fall 2017 Cal Poly, Team S18-G3, Forte Fall 2017 的会员
CPSU-FORTE-F17S18G3
4 名成员
创作了14篇指南
How about the square thing with the stick and hinges that the joystick is attached to? I think it’s called the Module. I have a joystick drift / drifting problem and that may help me out. Thanks.
Cory C - 回复
Agreed. That’s actually the part I need to replace too. The module.
Thomas Tomchak -
followed this guide to take the controller apart because I had a joystick that was sticking, my solution was to put some 3in1 oil on the module that was sticking and it seems to be working a lot better now.
John Jaggi - 回复
@corytc and @tomchak I did replace the module, in general, you buy (Amazon or eBay) you will receive a module of 6 modules you need a multimeter and test each module interface, measure both resistances and subtract them, the one nearest zero is the module you will use since is the one with least drift from the factory.
Just disassemble it, turn upside down uses a solder remover and unsolder the old one, place the new one solder back, boom you are done.
Like you will need an iron solder with medium and thin tips, I used lead-free solder, so is a patience test, be careful with the wires from the rumbles, try not to unsolder them since is a thin wire and is difficult, like I have big hands so took me a while to solder back.
Luis Vitorio Cargnini - 回复
添加评论
浏览统计数据:
过去的24小时: 37
过去的7天: 233
过去的30天: 887
总计 24,513
