跳转到主内容
Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement
你所需要的
  1. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement, Bumper: 步骤 1 中的图像 1,1
    • Remove the battery cover.
    • Remove batteries.
  2. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 步骤 2 中的图像 1,3 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 步骤 2 中的图像 2,3 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 步骤 2 中的图像 3,3
    • Grip the controller firmly to remove the side handle cover.
    • Use a flathead screwdriver or a spudger to wedge between the seams of the front to the side handle of the controller.
    • Move the flathead screwdriver all the way around the side plates seam and push the plate forward.
  3. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 步骤 3 中的图像 1,2 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 步骤 3 中的图像 2,2
    • Use a screwdriver and punch a hole directly in the center label. There you will find a hidden screw.
    • Remove the five 10mm screws located on the back of the controller using a T8 screwdriver.
  4. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 步骤 4 中的图像 1,2 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 步骤 4 中的图像 2,2
    • Remove the backplate.
  5. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 步骤 5 中的图像 1,2 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 步骤 5 中的图像 2,2
    • Remove the faceplate.
  6. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 步骤 6 中的图像 1,3 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 步骤 6 中的图像 2,3 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 步骤 6 中的图像 3,3
    • Remove the cover piece surrounding the Xbox button off of its pegs.
    • Firmly hold controller and push cover piece up from the pegs.
    • Press the Xbox button down to assist in the unclipping of the piece.
  7. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 步骤 7 中的图像 1,2 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 步骤 7 中的图像 2,2
    • Remove the broken bumper by unclipping it from its pegs.
    • Hold the controller firmly and push the bumper piece up from its pegs to unclip.
  8. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 步骤 8 中的图像 1,3 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 步骤 8 中的图像 2,3 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 步骤 8 中的图像 3,3
    • Align the replacement bumper onto the pegs, push gently and click into place.
结论
20等其他人完成本指南。
3指南评论
On my controller the screws were T8 security type, so you'll need bits with a hole in the middle
Sean H - 回复
Is there a way to do this without removing all of the front and grip.
Alan Marantos - 回复
J'ai un problème c'est que j'arrive pas à retirer les 5 vis certaines sont bloqués j'ai l'impression vous auriez pas une solution
Ratz - 回复
添加评论
浏览统计数据:
过去 24 小时: 23
过去 7 天: 110
过去 30 天: 478
总计 61,388
