跳转到主内容
Xbox One Wireless Controller D-Pad Replacement
你所需要的
  1. Xbox One Wireless Controller D-Pad Replacement, Battery Pack: 步骤 1 中的图像 1,1
    • Remove the battery pack cover.
    • Remove batteries.
  2. Xbox One Wireless Controller D-Pad Replacement, Side Handles: 步骤 2 中的图像 1,2 Xbox One Wireless Controller D-Pad Replacement, Side Handles: 步骤 2 中的图像 2,2
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
  3. Xbox One Wireless Controller D-Pad Replacement, Screws: 步骤 3 中的图像 1,2 Xbox One Wireless Controller D-Pad Replacement, Screws: 步骤 3 中的图像 2,2
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
  4. Xbox One Wireless Controller D-Pad Replacement, Backplate: 步骤 4 中的图像 1,1
    • Remove the backplate.
  5. Xbox One Wireless Controller D-Pad Replacement, Faceplate: 步骤 5 中的图像 1,1
    • Remove the faceplate.
  6. Xbox One Wireless Controller D-Pad Replacement, Metal Frame: 步骤 6 中的图像 1,2 Xbox One Wireless Controller D-Pad Replacement, Metal Frame: 步骤 6 中的图像 2,2
    • Pry off the metal frame around the D-Pad.
  7. Xbox One Wireless Controller D-Pad Replacement, D-Pad: 步骤 7 中的图像 1,1
    • Lift the D-Pad out of its housing.
结论
44等其他人完成本指南。
Garrett George
于01/22/15注册
6,127 声望
创作了3篇指南
团队
Cal Poly, Team 20-15, Maness Winter 2015 Cal Poly, Team 20-15, Maness Winter 2015 的会员
CPSU-MANESS-W15S20G15
5 名成员
创作了50篇指南
7条评论
Can you show me how to replace xbox one controller 3.5mm stereo jack dpad
Arief Hidayat - 回复
This model of the xbox one controller does not feature a 3.5mm headphone jack. Please look at the guides for later models of the xbox one controller.
Brandon -
it's exactly the same like shown above :)
David Schmidt - 回复
How do u fix one of the silver things behind the d-pad?
Bob - 回复
How do fix the silver things behind each d-pad
Bob - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 101
过去 30 天: 302
总计 61,484
