跳转到主内容
加入维修社区 - 创建账户
Xbox One Wireless Controller 1697 Thumbstick Replacement
你所需要的
  1. Xbox One Wireless Controller 1697 Thumbstick  Replacement, Thumbstick: 步骤 1 中的图像 1,1
    • Slide the battery pack cover toward the top of the controller to remove it.
    • Remove batteries.
    询问修复机器人
    添加评论
  2. Xbox One Wireless Controller 1697 Thumbstick  Replacement: 步骤 2 中的图像 1,2 Xbox One Wireless Controller 1697 Thumbstick  Replacement: 步骤 2 中的图像 2,2
    • We recommend using a plastic spudger to prevent damage to your controller. However, using a metal spudger, as shown in the picture, makes the work easier.
    • Hold firmly the controller, place the spudger into the top seam of the controller and carefully work all the way to the bottom.
    • Pry the side of handle away from the controller by moving the spudger back and forth around the side handle's seam.
    • Repeat this process for both side handles.
    询问修复机器人
    添加评论
  3. Xbox One Wireless Controller 1697 Thumbstick  Replacement: 步骤 3 中的图像 1,2 Xbox One Wireless Controller 1697 Thumbstick  Replacement: 步骤 3 中的图像 2,2
    • Using the T8 Security Torxs screwdriver, remove the five 10mm screws from the back of the controller.
    • One of the screws is hidden behind the label.
    • You can punch a hole using a screwdriver or peel off the label.
    询问修复机器人
    添加评论
  4. Xbox One Wireless Controller 1697 Thumbstick  Replacement: 步骤 4 中的图像 1,3 Xbox One Wireless Controller 1697 Thumbstick  Replacement: 步骤 4 中的图像 2,3 Xbox One Wireless Controller 1697 Thumbstick  Replacement: 步骤 4 中的图像 3,3
    • Remove the back plate.
    询问修复机器人
    添加评论
  5. Xbox One Wireless Controller 1697 Thumbstick  Replacement: 步骤 5 中的图像 1,1
    • Remove the faceplate
    询问修复机器人
    添加评论
  6. Xbox One Wireless Controller 1697 Thumbstick  Replacement: 步骤 6 中的图像 1,3 Xbox One Wireless Controller 1697 Thumbstick  Replacement: 步骤 6 中的图像 2,3 Xbox One Wireless Controller 1697 Thumbstick  Replacement: 步骤 6 中的图像 3,3
    • Select the thumbstick that you want to replace and pull it off its pole.
    添加评论
结论
取消:我没有完成这个指南。
30等其他人完成本指南。
Emely
于09/27/17注册
920 声望
撰写一个指南
团队
USF Tampa, Team S9-G1, Remmell Fall 2017 USF Tampa, Team S9-G1, Remmell Fall 2017 的会员
USFT-REMMELL-F17S9G1
4 名成员
创作了14篇指南
1指南评论
Hello. I have an controller but it isn't working right. The right stick wont register when i push it down. I spilled cola on it. Any tips?
Isak - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 45
过去 30 天: 190
总计 28,063
