跳转到主内容
  1. 这个步骤还没有翻译 帮忙翻译一下
    Remove the battery pack cover.
    • Remove the battery pack cover.
    • Remove the two AA batteries.
    • Carefully remove the sticker or puncture to reveal the screw.
  2. 这个步骤还没有翻译 帮忙翻译一下
    Remove the side handles by wedging the spudger around the side panels. Pry the side panel by moving the spudger back and forth. You must do this along the entire seam to remove the side handle panel. There are seven clips that need to be opened to remove each handle panel.
    • Remove the side handles by wedging the spudger around the side panels.
    • Pry the side panel by moving the spudger back and forth. You must do this along the entire seam to remove the side handle panel.
    • There are seven clips that need to be opened to remove each handle panel.
  3. 这个步骤还没有翻译 帮忙翻译一下
    Removing the side handles allows access to remove the faceplate. Use the TORX TR8 screwdriver to remove the five TR9 Torx screws. Use the TORX TR8 screwdriver to remove the five TR9 Torx screws.
    • Removing the side handles allows access to remove the faceplate.
    • Use the TORX TR8 screwdriver to remove the five TR9 Torx screws.
  4. 这个步骤还没有翻译 帮忙翻译一下
    Now that the bumpers are easily visible make sure to clean any dirt or grime that may be around the bumpers. The bumpers are connected by a middle plastic cover that is around the Xbox home button. Remove this plastic piece by lifting the plastic cover over the two pins, pressing the home button in, and pushing the cover towards the top of the controller. Be aware of the sync button loosely placed under the plastic covering. Ensure it is put back before putting back the bumper/plastic cover assembly.
    • Now that the bumpers are easily visible make sure to clean any dirt or grime that may be around the bumpers.
    • The bumpers are connected by a middle plastic cover that is around the Xbox home button. Remove this plastic piece by lifting the plastic cover over the two pins, pressing the home button in, and pushing the cover towards the top of the controller.
    • Be aware of the sync button loosely placed under the plastic covering. Ensure it is put back before putting back the bumper/plastic cover assembly.
    • Remove the current bumper assembly by pulling them off the plastic cover.
  5. 这个步骤还没有翻译 帮忙翻译一下
    The controller is now ready for the new bumper assembly. Align the new bumpers onto the top of the controller by holding down the triggers and aligning the four pins on both sides. Set the new home button cover over the micro USB port, push the home button in, and pull the cover over the two pins shown.
    • The controller is now ready for the new bumper assembly.
    • Align the new bumpers onto the top of the controller by holding down the triggers and aligning the four pins on both sides.
    • Set the new home button cover over the micro USB port, push the home button in, and pull the cover over the two pins shown.
终点
42等其他人完成本指南。
Ryan Burroughs
于2017年09月25日注册
1,032 信誉积分
创作了2篇指南
团队
USF Tampa, Team S9-G1, Remmell Fall 2017 USF Tampa, Team S9-G1, Remmell Fall 2017 的会员
USFT-REMMELL-F17S9G1
4 名成员
创作了9篇指南
10条评论
the bumpers take some finesse to remove, so be patient
Vincent - 回复
You should add a security hex screwdriver to your tools list, along with the gauge that is required.
Travis Weston - 回复
There is a fifth screw in the battery compartment that holds the faceplate on. Take an exacto knife and cut out sticker where the hole is.
Scott Williams - 回复
Could you elaborate on the “remove the bumpers” part (last step) please, thank you.
r.d.huijsmans - 回复
Great guide. Helped me easily fix a sticky bumper and save 60$
Bryon Crockett - 回复
添加评论
浏览统计数据:
过去的24小时: 37
过去的7天: 286
过去的30天: 1,000
总计 49,836
